Ana içeriğe geç
Nikon D7100 LCD Screen Replacement
Neye ihtiyacın var
  1. Nikon D7100 LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the five screws on the bottom of the camera with a JIS #000 head screwdriver.
  2. Nikon D7100 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Remove the 3 screws under the battery flap and remove the bottom cover.
  3. Nikon D7100 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Remove the 2 screws inside the camera on the back corners.
  4. Nikon D7100 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Open the HDMI flap and remove the 2 screws.
  5. Nikon D7100 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Remove the screw next to the camera strap loop.
  6. Nikon D7100 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Remove the 2 screws on each side of the view finder.
  7. Nikon D7100 LCD Screen Replacement: adım 7, 1 resimden 1.
    • Remove the 2 screws above and below the SD card flap.
  8. Nikon D7100 LCD Screen Replacement: adım 8, 1 resimden 1.
    • Peel off the adhesive leather screw cover and remove the 2 screws under it.
  9. Nikon D7100 LCD Screen Replacement: adım 9, 2 resimden 1. Nikon D7100 LCD Screen Replacement: adım 9, 2 resimden 2.
    • Remove the Diopter adjustment control sticker and remove the screw under it.
  10. Nikon D7100 LCD Screen Replacement: adım 10, 1 resimden 1.
    • Separate the back panel of the camera from the actual camera.
    • Be careful not to tear any of the ribbon cables.
  11. Nikon D7100 LCD Screen Replacement: adım 11, 1 resimden 1.
    • Disconnect the LCD ribbon cables and power cable from the motherboard.
  12. Nikon D7100 LCD Screen Replacement: adım 12, 2 resimden 1. Nikon D7100 LCD Screen Replacement: adım 12, 2 resimden 2.
    • Unscrew all 16 screws around the back plate of the camera.
  13. Nikon D7100 LCD Screen Replacement: adım 13, 1 resimden 1.
    • Then unscrew the remaining screws holding the back plate to the LCD.
    • Then simply remove the plate with the LCD.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Wesley Eveld
736 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G6, Cheng Spring 2018 USF Tampa, Team S11-G6, Cheng Spring 2018 üyesi
USFT-CHENG-S18S11G6
4 Üyeler
6 adet Kılavuz yazıldı
9Kılavuz Yorumları
I DID IT! A couple notes: 1) You don’t need to disconnect the ribbon cables from the body. I’m new to fine electronics repair like this and I didn’t want to mess around with more cables than necessary. 2) My body doesn’t have a plastic cover over the LCD (probably why it broke…) and as such I had to reallllly pry it off. 3) Learn how to reconnect ribbon cables - I had no idea.
Patrick O'Hare - Yanıt
Are all screws the same size ?
trevee359 - Yanıt
A couple of points. This is listed as a LCD display replacement. Says only said to buy tools… Need the LCD screen as well. No idea of cost or a link to buy same. Also, you do not show removing the screen and remounting. I appreciate all the instructions on screws, but do not feel this was complete. Thanks for your instructions to this point.
Carl Bryant II - Yanıt
That’s very easy guide to understand. I hope to see a full guide for the Nikon D7200. thank you http://www.nikonbundle.com/nikon-d7200-b...
Deve Marko - Yanıt
My replacement screen cost about £44 gbp pounds from China on Ebay. The main ribbon cable is released by flipping up the thin dark grey strip opposite the ribbon using a finger nail or plastic tool on the socket then you just gently pull the cable out, the thin cable is wee bit different, using a small screw driver or dentist tool just unclip and pull/push it down towards the thin ribbon cable then slide ribbon out. When all done clean the screen on the camera and fit a thin glass protector from JJC on ebay to give more protection.
a.brown.1 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 165
Her zaman: 8,272
