Ana içeriğe geç
Nikon D80 Rear LCD Screen Replacement
Neye ihtiyacın var
  1. Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: adım 1, 3 resimden 1. Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: adım 1, 3 resimden 2. Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: adım 1, 3 resimden 3.
    • Using a Philips #00 screwdriver, remove the four 6.2mm from the left and right sides of the outer cover.
    FixBot'a Sor
    Yorum Ekle
  2. Nikon D80 Rear LCD Screen Replacement: adım 2, 3 resimden 1. Nikon D80 Rear LCD Screen Replacement: adım 2, 3 resimden 2. Nikon D80 Rear LCD Screen Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
    • Pull the orange connector cable away from the main body of the camera using the tweezers.
    • Remove the back cover.
    FixBot'a Sor
    Yorum Ekle
  3. Nikon D80 Rear LCD Screen Replacement: adım 3, 2 resimden 1. Nikon D80 Rear LCD Screen Replacement: adım 3, 2 resimden 2.
    • Using a Philips #00 screwdriver, remove the three 4.3 mm screws by rotating screwdriver to the left.
    • Use the Phillips #00 screwdriver to remove the two 3.4 mm screws.
    FixBot'a Sor
    Yorum Ekle
  4. Nikon D80 Rear LCD Screen Replacement: adım 4, 2 resimden 1. Nikon D80 Rear LCD Screen Replacement: adım 4, 2 resimden 2.
    • Using blunt tweezers, gently flip the small locking flap of the zero force insertion connector up for both connectors.
    • Use blunt tweezers to pull the left ribbon connector out of the zero insertion force connector.
    • Using the same tweezers, pull the right ribbon connector out of the zero insertion force connector.
    FixBot'a Sor
    Yorum Ekle
  5. Nikon D80 Rear LCD Screen Replacement: adım 5, 2 resimden 1. Nikon D80 Rear LCD Screen Replacement: adım 5, 2 resimden 2.
    • Slide out the LCD screen by pulling towards the right.
    • Remove the LCD screen.
    • The buttons beside the screen fall out easily. Remember where they were and put them back when finished with the screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sara Martin
610 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Leahy Fall 2017 USF Tampa, Team S1-G1, Leahy Fall 2017 üyesi
USFT-LEAHY-F17S1G1
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 54
Her zaman: 4,113
