Giriş
Potential damage could occur to the rear LCD screen which could affect performance. For safety purposes, please remove the battery before working with any electronic components.
Neye ihtiyacın var
Using a Philips #00 screwdriver, remove the four 6.2mm from the left and right sides of the outer cover.
Using blunt tweezers, gently flip the small locking flap of the zero force insertion connector up for both connectors.
Use blunt tweezers to pull the left ribbon connector out of the zero insertion force connector.
Using the same tweezers, pull the right ribbon connector out of the zero insertion force connector.
Bir başkası bu kılavuzu tamamladı.
