Ana içeriğe geç
Nikon D90 Flash Bulb Replacement
Neye ihtiyacın var
  1. Nikon D90 Flash Bulb Replacement, Open the Flash: adım 1, 3 resimden 1. Nikon D90 Flash Bulb Replacement, Open the Flash: adım 1, 3 resimden 2. Nikon D90 Flash Bulb Replacement, Open the Flash: adım 1, 3 resimden 3.
    • Use a plastic opening tool to lift up the flash.
  2. Nikon D90 Flash Bulb Replacement, Flash Casing Screws: adım 2, 2 resimden 1. Nikon D90 Flash Bulb Replacement, Flash Casing Screws: adım 2, 2 resimden 2.
    • Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
    • Be careful not to strip the screw heads.
  3. Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: adım 3, 3 resimden 1. Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: adım 3, 3 resimden 2. Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: adım 3, 3 resimden 3.
    • Use a plastic opening tool and carefully pry open the top casing of the flash.
    • Then, lift off the top casing of the flash.
  4. Nikon D90 Flash Bulb Replacement, Removing the Bulb Tape: adım 4, 2 resimden 1. Nikon D90 Flash Bulb Replacement, Removing the Bulb Tape: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Carefully unclip the bulb casing from the plastic casing using tweezers.
    • Remove the black and white tape on the bulb casing.
    • This tape is what holds the wires and bulb in place.
  5. Nikon D90 Flash Bulb Replacement, Removing the Bulb: adım 5, 3 resimden 1. Nikon D90 Flash Bulb Replacement, Removing the Bulb: adım 5, 3 resimden 2. Nikon D90 Flash Bulb Replacement, Removing the Bulb: adım 5, 3 resimden 3.
    • Remove the rubber stopper on the left and right side of the bulb.
    • Separate the rubber stopper from the white and black tape.
    • The bulb can now be slid out and replaced.
    • Be careful not to break the bulb or cut yourself on the broken bulb.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
jonothon cawley
354 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-7, Duarte Fall 2014 UMass Dartmouth, Team 1-7, Duarte Fall 2014 üyesi
UMASSD-DUARTE-F14S1G7
3 Üyeler
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
thanks for instruction…………really helpfull
hebi - Yanıt
Hi guys do you know where to get this bulb?please help
Martin Mitter - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 22
Son 30 gün: 83
Her zaman: 7,416
