Ana içeriğe geç
Nikon D90 Flash Hinge Spring Replacement
Neye ihtiyacın var
    1. Nikon D90 Flash Hinge Spring Replacement, Open the Flash: adım 1, 3 resimden 1. Nikon D90 Flash Hinge Spring Replacement, Open the Flash: adım 1, 3 resimden 2. Nikon D90 Flash Hinge Spring Replacement, Open the Flash: adım 1, 3 resimden 3.
      • Use a plastic opening tool to lift up the flash.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon D90 Flash Hinge Spring Replacement, Flash Casing Screws: adım 2, 2 resimden 1. Nikon D90 Flash Hinge Spring Replacement, Flash Casing Screws: adım 2, 2 resimden 2.
      • Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
      • Be careful not to strip the screw heads.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon D90 Flash Hinge Spring Replacement, Removing the Top Flash Casing: adım 3, 3 resimden 1. Nikon D90 Flash Hinge Spring Replacement, Removing the Top Flash Casing: adım 3, 3 resimden 2. Nikon D90 Flash Hinge Spring Replacement, Removing the Top Flash Casing: adım 3, 3 resimden 3.
      • Use a plastic opening tool and carefully pry open the top casing of the flash.
      • Then, lift off the top casing of the flash.
      FixBot'a Sor
      Yorum Ekle
    1. Nikon D90 Flash Hinge Spring Replacement, Loosening the Spring Screw: adım 4, 2 resimden 1. Nikon D90 Flash Hinge Spring Replacement, Loosening the Spring Screw: adım 4, 2 resimden 2.
      • Using a PH00 screwdriver, loosen the 3.3 mm Phillips screw from the spring.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon D90 Flash Hinge Spring Replacement, Releasing the Spring: adım 5, 2 resimden 1. Nikon D90 Flash Hinge Spring Replacement, Releasing the Spring: adım 5, 2 resimden 2.
      • Use a plastic opening tool and carefully pry up the spring arm.
      • Doing this with release the pressure of the spring.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon D90 Flash Hinge Spring Replacement, Removing the Spring: adım 6, 2 resimden 1. Nikon D90 Flash Hinge Spring Replacement, Removing the Spring: adım 6, 2 resimden 2.
      • Finish removing the screw holding the spring in place.
      • The spring can now be removed and replaced.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Matthew Grota
598 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-7, Duarte Fall 2014 UMass Dartmouth, Team 1-7, Duarte Fall 2014 üyesi
UMASSD-DUARTE-F14S1G7
3 Üyeler
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
These are great tutorials,
I was looking for one on how to fix the pop up flash not locking down,
It was bought second hand and dropped on the logo,
The front panel needed to be replaced,
Now for the Flash that is constantly up.
Any links? jjryzler@gmail.com
Ryad Arlan - Yanıt Paylaş
My flash won't stay down. I think the piece that clips in to keep it closed may have broken. Is there a way to fix?
Linda Wick - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 42
Her zaman: 4,965
