Ana içeriğe geç
Nikon D90 Rear Case Replacement
Neye ihtiyacın var
  1. Nikon D90 Rear Case Replacement, Rear Case: adım 1, 2 resimden 1. Nikon D90 Rear Case Replacement, Rear Case: adım 1, 2 resimden 2.
    • Slide the eyepiece up and off the viewfinder.
  2. Nikon D90 Rear Case Replacement: adım 2, 1 resimden 1.
    • Using a PH000 screwdriver, remove the two 4.8mm Phillips screws from the back of the viewfinder.
    • Some screws may be JIS. Be wary of this if your PH000 does not feel like it is properly gripping the screws.
  3. Nikon D90 Rear Case Replacement: adım 3, 1 resimden 1.
    • Remove the two 6.4mm Phillips screws on the right side of the camera, near the SD card slot.
  4. Nikon D90 Rear Case Replacement: adım 4, 1 resimden 1.
    • Remove the two 6.4mm Phillips screws on the left side of the camera, near the I/O ports.
  5. Nikon D90 Rear Case Replacement: adım 5, 1 resimden 1.
    • On the bottom of the camera,
    • remove the two 5.3mm Phillips screws
    • and the other two 6.3mm Phillips screws.
  6. Nikon D90 Rear Case Replacement: adım 6, 3 resimden 1. Nikon D90 Rear Case Replacement: adım 6, 3 resimden 2. Nikon D90 Rear Case Replacement: adım 6, 3 resimden 3.
    • Using a spudger, separate the bottom panel from the rear case just enough to clear the two clips on the rear casing in the next step.
  7. Nikon D90 Rear Case Replacement: adım 7, 2 resimden 1. Nikon D90 Rear Case Replacement: adım 7, 2 resimden 2.
    • Lift the rear case off of the back of the camera.
    • Don't pull the casing completely off yet, as the ribbon cables are still connected.
    • Be mindful of the two clips, making sure to keep the bottom panel far enough away to clear them.
  8. Nikon D90 Rear Case Replacement: adım 8, 1 resimden 1.
    • Set the rear casing off to the side so you can access the ZIF connectors.
    • The orientation shown in the picture seems to be the best position for the casing to sit comfortably without stressing the ribbon cable connections.
  9. Nikon D90 Rear Case Replacement: adım 9, 3 resimden 1. Nikon D90 Rear Case Replacement: adım 9, 3 resimden 2. Nikon D90 Rear Case Replacement: adım 9, 3 resimden 3.
    • Use a spudger to lift the black tab on the ZIF connector.
    • Disconnect the ribbon cables from their respective ZIF connectors on the logic board.
  10. Nikon D90 Rear Case Replacement: adım 10, 1 resimden 1.
    • Separate the rear casing from the camera.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Ryan Lutz
3.014 İtibar
3 adet Kılavuz yazıldı
2Kılavuz Yorumları
good guidance,easy to follow,thanks
ramalingeswarao kaza - Yanıt
I want to replace my Nikon D90 DSLR bad LCD, this guide will save me from costly repairs.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 34
Her zaman: 4,432
