Ana içeriğe geç
Nikon D90 Rear Display Buttons Replacement
Neye ihtiyacın var
  1. Nikon D90 Rear Display Buttons Replacement, Removing Casing Screws: adım 1, 2 resimden 1. Nikon D90 Rear Display Buttons Replacement, Removing Casing Screws: adım 1, 2 resimden 2.
    • Locate the screws on both sides of the camera.
    • Remove the four 6.3 mm Phillips screws using a PH00 screwdriver.
    • Be careful not to strip the screws.
  2. Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: adım 2, 3 resimden 1. Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: adım 2, 3 resimden 2. Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: adım 2, 3 resimden 3.
    • Use a plastic opening tool to separate the rear case from the camera.
  3. Nikon D90 Rear Display Buttons Replacement, Disconnecting the Ribbon Cables: adım 3, 2 resimden 1. Nikon D90 Rear Display Buttons Replacement, Disconnecting the Ribbon Cables: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • After, remove the two orange ribbon connectors attached to the interior of the camera with tweezers.
    • Make sure to remove the ribbon cables carefully from the connectors to avoid damaging the camera.
  4. Nikon D90 Rear Display Buttons Replacement, Removing the Screws from the Rear Casing: adım 4, 2 resimden 1. Nikon D90 Rear Display Buttons Replacement, Removing the Screws from the Rear Casing: adım 4, 2 resimden 2.
    • Remove the screws from the back assembly with a Phillips (PH00) head screwdriver.
    • Remove the ten 5.3 mm Phillips screws.
    • Remove the three 4.3 mm Phillips screws.
  5. Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: adım 5, 3 resimden 1. Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: adım 5, 3 resimden 2. Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: adım 5, 3 resimden 3.
    • Use a plastic opening tool to separate the LCD and metal plates from the casing.
  6. Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: adım 6, 3 resimden 1. Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: adım 6, 3 resimden 2. Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: adım 6, 3 resimden 3.
    • Use a plastic opening tool to separate the buttons from the casing.
    • Remove the 4.3 mm Phillips screw from the knob using a PH00 screwdriver.
Sonuç
Bir başkası bu kılavuzu tamamladı.
jonothon cawley
354 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-7, Duarte Fall 2014 UMass Dartmouth, Team 1-7, Duarte Fall 2014 üyesi
UMASSD-DUARTE-F14S1G7
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 2,683
