Ana içeriğe geç
Nikon D90 Replacing the SB / IF card
Neye ihtiyacın var
  1. Nikon D90 Replacing the SB / IF card, Remove the bottom cover: adım 1, 1 resimden 1.
    • Remove the three screw in red
    • Remove the three long screw in orange
    • Remove the screw in yellow
    • Use a little of WD40 if the screw is blocked
  2. Nikon D90 Replacing the SB / IF card, Remove the back cover: adım 2, 3 resimden 1. Nikon D90 Replacing the SB / IF card, Remove the back cover: adım 2, 3 resimden 2. Nikon D90 Replacing the SB / IF card, Remove the back cover: adım 2, 3 resimden 3.
    • Remove the 4 screw in green
    • Remove the 2 screw in yellow
  3. Nikon D90 Replacing the SB / IF card: adım 3, 3 resimden 1. Nikon D90 Replacing the SB / IF card: adım 3, 3 resimden 2. Nikon D90 Replacing the SB / IF card: adım 3, 3 resimden 3.
    • Slacken the grip side of the cover first
    • Remove the cover wholly.
    • Be carefull with the two flex cables
  4. Nikon D90 Replacing the SB / IF card: adım 4, 3 resimden 1. Nikon D90 Replacing the SB / IF card: adım 4, 3 resimden 2. Nikon D90 Replacing the SB / IF card: adım 4, 3 resimden 3.
    • Disconnect the FPC of the back cover
    • Toggle up the black plate to free the flex cable
    • Remove the grip cover by rotating
  5. Nikon D90 Replacing the SB / IF card, Disconnect all the cables - part 1/3: adım 5, 3 resimden 1. Nikon D90 Replacing the SB / IF card, Disconnect all the cables - part 1/3: adım 5, 3 resimden 2. Nikon D90 Replacing the SB / IF card, Disconnect all the cables - part 1/3: adım 5, 3 resimden 3.
    • Toggle up the black plate and disconnect the flex cable
    • Toggle up the white plate and disconnect the flex cable
    • Push up the right slide of the connector to free it
  6. Nikon D90 Replacing the SB / IF card, Disconnect all the cables - part 2/3: adım 6, 1 resimden 1.
    • Push up the bottom of the connector to free it
  7. Nikon D90 Replacing the SB / IF card, Detach the protection plate: adım 7, 3 resimden 1. Nikon D90 Replacing the SB / IF card, Detach the protection plate: adım 7, 3 resimden 2. Nikon D90 Replacing the SB / IF card, Detach the protection plate: adım 7, 3 resimden 3.
    • Remove the six screws to free the protection plate
    • Disconnect the white cables
    • Disconnect the microphone Cable
  8. Nikon D90 Replacing the SB / IF card, Disconnect all cables - Part 3/3: adım 8, 3 resimden 1. Nikon D90 Replacing the SB / IF card, Disconnect all cables - Part 3/3: adım 8, 3 resimden 2. Nikon D90 Replacing the SB / IF card, Disconnect all cables - Part 3/3: adım 8, 3 resimden 3.
    • Disconnect the speaker cable
    • Remove the two screws to free the PCB
    • Toggle th PCB from Left to Right
  9. Nikon D90 Replacing the SB / IF card, Disconnect the cable on the bottom of the PCB: adım 9, 1 resimden 1.
    • Disconnect the black cables
  10. Nikon D90 Replacing the SB / IF card, Free the IF/SB PCB: adım 10, 2 resimden 1. Nikon D90 Replacing the SB / IF card, Free the IF/SB PCB: adım 10, 2 resimden 2.
    • Push the IF/SB PCB
    • Unsolder the 3 Wires ( Red, Black, Orange )
Sonuç
To reassemble your device, follow the instructions in reverse order.
Bu çevirmenlere özel teşekkürler:
fr en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
JOLY
182 İtibar
1 Kılavuz yazıldı
Ekip
Nexurium - Bastien JOLY Nexurium - Bastien JOLY üyesi
Business
1 Üye
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 36
Her zaman: 2,550
