Ana içeriğe geç
Nikon N2000 (F301) Battery Compartment Replacement
Neye ihtiyacın var
    • In this guide we will be referring to 'left' and 'right' as though the camera's front (the part that says Nikon) is facing you.
    • Unscrew the large metal screw on the left side using a quarter and remove the battery cover.(Picture not available)
  1. Nikon N2000 (F301) Battery Compartment Replacement: adım 2, 1 resimden 1.
    • Use a 00 Phillips head screwdriver to remove the small screw on the far left of the battery compartment.
  2. Nikon N2000 (F301) Battery Compartment Replacement: adım 3, 1 resimden 1.
    • Pull up on the tab to remove the batteries.
    • Note: The batteries will probably fall out of their holder.
  3. Nikon N2000 (F301) Battery Compartment Replacement: adım 4, 1 resimden 1.
    • Use a 00 Phillips head screwdriver to remove the four screws from inside the case.
  4. Nikon N2000 (F301) Battery Compartment Replacement: adım 5, 1 resimden 1.
    • Remove the battery compartment from the camera.
    • Note: On some models, the compartment is soldered in by the wires shown. If so you will need to desolder them.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Zachary Phillips
247 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-26, Garner Spring 2011 Cal Poly, Team 25-26, Garner Spring 2011 üyesi
CPSU-GARNER-S11S25G26
3 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Hey, i lost the bracket… do u guys have any idea where could i get one?
David mate - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 36
Son 30 gün: 161
Her zaman: 17,198
