Giriş
Is your film door looking ratty and not working? Don't give up on your camera and try replacing your film door! This guide will explain how to replace the film door in a Nikon N80/F80 Camera.
Neye ihtiyacın var
3 farklı kişi bu kılavuzu tamamladı.
5 Yorum
Hi where can buy a replacement door please?
Uscamera.com carries them.
D S -
It's unnecessary to disassemble the camera to this extent. You just need to disconnect the ribbon cable (which involves removing the spring loaded guide next to the door hinge and unlatch the connector underneath) and unscrew the door pivot screw on the underside of the camera. This document lays it out quite nicely:
https://www.jeremymuddphoto.com/blog/202...
Thank you all for the information.
