Ana içeriğe geç
Nikon N80 Film Door Replacement
Neye ihtiyacın var
  1. Nikon N80 Film Door Replacement, Film Door: adım 1, 1 resimden 1.
    • Make sure the On/Off switch is in the Off position.
  2. Nikon N80 Film Door Replacement: adım 2, 3 resimden 1. Nikon N80 Film Door Replacement: adım 2, 3 resimden 2. Nikon N80 Film Door Replacement: adım 2, 3 resimden 3.
    • Remove the four 4.8mm screws on the top section of the camera using a PH00 Phillips screwdriver.
    • Two of the screws are located by the viewfinder and and the other two are on each side of the camera.
  3. Nikon N80 Film Door Replacement: adım 3, 2 resimden 1. Nikon N80 Film Door Replacement: adım 3, 2 resimden 2.
    • Rotate the camera so the bottom plate is accessible.
    • Remove the seven 4.8mm screws on the bottom plate of the camera using a PH00 Phillips screwdriver.
    • Remove the two 4.8mm screws on the bottom plate of the camera using a PH00 Phillips screwdriver.
    • Remove the bottom plate.
  4. Nikon N80 Film Door Replacement: adım 4, 1 resimden 1.
    • Remove the five silver 4.8mm screws on the lens mount using a PH00 Phillips screwdriver.
    • Extract the lens mount.
  5. Nikon N80 Film Door Replacement: adım 5, 3 resimden 1. Nikon N80 Film Door Replacement: adım 5, 3 resimden 2. Nikon N80 Film Door Replacement: adım 5, 3 resimden 3.
    • Remove the seven 4.8mm screws on front camera plate using a PH00 Phillips screwdriver.
    • One of the screws is located on the battery chamber side of the camera, two are next to the film door release lever, two are located below the "Nikon" logo, and the last two are located above the "Nikon" logo in the Speedlight compartment.
  6. Nikon N80 Film Door Replacement: adım 6, 1 resimden 1.
    • Remove the two 4.8mm screws in the battery compartment of the camera using a PH00 Phillips screwdriver.
    • Separate the three front camera plates from the camera.
  7. Nikon N80 Film Door Replacement: adım 7, 1 resimden 1.
    • Gently disconnect the top section of the camera from the body.
    • Don't pull the top section off too hard or the wire and ribbon within the camera may disconnect.
  8. Nikon N80 Film Door Replacement: adım 8, 1 resimden 1.
    • Turn the camera over to reveal the film door.
    • Remove the film door.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Maegan Viloria
724 İtibar
5 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 1-7, Bruce Fall 2015 CSU Fullerton, Team 1-7, Bruce Fall 2015 üyesi
CSUF-BRUCE-F15S1G7
3 Üyeler
10 adet Kılavuz yazıldı
5Kılavuz Yorumları
To replace the camera door, simply unscrew one screw under the door and three screws in the door to disconnect the cable that connects the camera to the door.
tadeuszse - Yanıt
Hi where can buy a replacement door please?
jenrossiter - Yanıt
Uscamera.com carries them.
D S -
It's unnecessary to disassemble the camera to this extent. You just need to disconnect the ribbon cable (which involves removing the spring loaded guide next to the door hinge and unlatch the connector underneath) and unscrew the door pivot screw on the underside of the camera. This document lays it out quite nicely:
https://www.jeremymuddphoto.com/blog/202...
Bruce H McIntosh - Yanıt
Thank you all for the information.
gabrielpurziani - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 22
Son 30 gün: 105
Her zaman: 6,614
