Ana içeriğe geç
Ninja AF161 Max XL Gray Frame Replacement
Neye ihtiyacın var
  1. Ninja AF161 Max XL Gray Frame Replacement, Back Vent Cover: adım 1, 1 resimden 1.
    • The back vent cover is directly above where the power cord protrudes.
  2. Ninja AF161 Max XL Gray Frame Replacement: adım 2, 2 resimden 1. Ninja AF161 Max XL Gray Frame Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #2 screwdriver to unscrew and remove four 1 cm screws from the panel.
  3. Ninja AF161 Max XL Gray Frame Replacement: adım 3, 2 resimden 1. Ninja AF161 Max XL Gray Frame Replacement: adım 3, 2 resimden 2.
    • Once unscrewed, remove all four screws in order to remove the back vent cover.
  4. Ninja AF161 Max XL Gray Frame Replacement, Gray Frame: adım 4, 2 resimden 1. Ninja AF161 Max XL Gray Frame Replacement, Gray Frame: adım 4, 2 resimden 2.
    • After you have the vent removed, you will see two 2.2 cm screws holding the casing in. Use a Phillips #1 screwdriver to remove the two screws.
    • Be wary that the two screws are quite tight and will require a bit of torsion to get out.
  5. Ninja AF161 Max XL Gray Frame Replacement: adım 5, 3 resimden 1. Ninja AF161 Max XL Gray Frame Replacement: adım 5, 3 resimden 2. Ninja AF161 Max XL Gray Frame Replacement: adım 5, 3 resimden 3.
    • Use the a plastic opening tool or a similar object to wedge between the silver top and black rim.
    • Pry all four sides towards the middle with a plastic opening tool to release the tabs.
    • The tabs on the top will make sounds while being detached from the device.
  6. Ninja AF161 Max XL Gray Frame Replacement: adım 6, 2 resimden 1. Ninja AF161 Max XL Gray Frame Replacement: adım 6, 2 resimden 2.
    • Unscrew the four 2.2 cm screws with a Phillips #1 screwdriver.
  7. Ninja AF161 Max XL Gray Frame Replacement: adım 7, 2 resimden 1. Ninja AF161 Max XL Gray Frame Replacement: adım 7, 2 resimden 2.
    • Lay the air fryer on its side.
  8. Ninja AF161 Max XL Gray Frame Replacement: adım 8, 2 resimden 1. Ninja AF161 Max XL Gray Frame Replacement: adım 8, 2 resimden 2.
    • Remove six 1.4 cm screws with the TR15 Torx Security Screwdriver.
  9. Ninja AF161 Max XL Gray Frame Replacement: adım 9, 1 resimden 1.
    • Keep the device on its side, and unscrew and remove two 1.4 cm screws with a Phillips #1 screwdriver.
  10. Ninja AF161 Max XL Gray Frame Replacement: adım 10, 1 resimden 1.
    • The lid can now be lifted off. Remove by prying the bottom apart and lifting.
    • After lifting the lid, you will see the white and yellow wire heads that connect the air fryer display screen to the motherboard.
  11. Ninja AF161 Max XL Gray Frame Replacement: adım 11, 3 resimden 1. Ninja AF161 Max XL Gray Frame Replacement: adım 11, 3 resimden 2. Ninja AF161 Max XL Gray Frame Replacement: adım 11, 3 resimden 3.
    • Pinch the white tab and wire head together and pull to release the connector.
    • Take care to not bend the circuit board while attempting removal of this connector. This will damage the circuit board.
Sonuç
Alina Sanchez
303 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 263
