Giriş
This guide is helpful for replacing the Ninja AF161 Max XL outer gray frame. These steps may be used to remove additional parts from the air fryer.
Neye ihtiyacın var
The back vent cover is directly above where the power cord protrudes.
After you have the vent removed, you will see two 2.2 cm screws holding the casing in. Use a Phillips #1 screwdriver to remove the two screws.
Neredeyse bitti!
Sonuç
