Ana içeriğe geç
Ninja Coffee Bar® Single-Serve System Frother Replacement
Neye ihtiyacın var
  1. Ninja Coffee Bar® Single-Serve System Frother Replacement, Frother: adım 1, 2 resimden 1. Ninja Coffee Bar® Single-Serve System Frother Replacement, Frother: adım 1, 2 resimden 2.
    • Remove four 6mm #1 Phillips head screws from under the basket area.
    • Remove the single 6mm #1 Phillips head screw from the side of the unit.
  2. Ninja Coffee Bar® Single-Serve System Frother Replacement: adım 2, 2 resimden 1. Ninja Coffee Bar® Single-Serve System Frother Replacement: adım 2, 2 resimden 2.
    • Gently pry the upper cover off the unit above the brew basket and above the water reservoir base and along the side of the upper cover.
  3. Ninja Coffee Bar® Single-Serve System Frother Replacement: adım 3, 2 resimden 1. Ninja Coffee Bar® Single-Serve System Frother Replacement: adım 3, 2 resimden 2.
    • Remove the single 6mm #1 Phillips head screw from the top of the unit. (The two smaller screws should remain attached.)
    • Using an extension, remove the two 6mm Phillips head screws from the side of the frother motor pivot.
  4. Ninja Coffee Bar® Single-Serve System Frother Replacement: adım 4, 3 resimden 1. Ninja Coffee Bar® Single-Serve System Frother Replacement: adım 4, 3 resimden 2. Ninja Coffee Bar® Single-Serve System Frother Replacement: adım 4, 3 resimden 3.
    • Pinch power connector and pull lighly to separate.
    • Pull motor straight up to separate from unit.
Sonuç
CJ Berg
444 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 üyesi
UMASSD-GULBRANDSEN-F18S5G4
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Awesome write-up. But does anyone know where a replacement frother arm can be purchased?
clarkwolfe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 1,491
