Ana içeriğe geç
Ninja Coffee Bar® Single-Serve System Power Cable Replacement
Neye ihtiyacın var
  1. Ninja Coffee Bar® Single-Serve System Power Cable Replacement, Power Cable: adım 1, 2 resimden 1. Ninja Coffee Bar® Single-Serve System Power Cable Replacement, Power Cable: adım 1, 2 resimden 2.
    • Unscrew the eight 6mm #1 Phillips head screws off the bottom panel.
    • Lift lower panel up while passing the power cord through the opening.
  2. Ninja Coffee Bar® Single-Serve System Power Cable Replacement: adım 2, 1 resimden 1.
    • Loosen two 6mm #1 Phillips head and remove clamp holding power cable.
  3. Ninja Coffee Bar® Single-Serve System Power Cable Replacement: adım 3, 2 resimden 1. Ninja Coffee Bar® Single-Serve System Power Cable Replacement: adım 3, 2 resimden 2.
    • Pull the power cable out exposing the two crimped ends.
    • Using a wire stripper/crimping tool, uncrimp wires.
    • Wiring connectors are sealed together making them difficult to disconnect. Cutting and rewiring should be considered.
Sonuç
Bir başkası bu kılavuzu tamamladı.
CJ Berg
444 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 üyesi
UMASSD-GULBRANDSEN-F18S5G4
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 480
