Ana içeriğe geç
Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement
Neye ihtiyacın var
  1. Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement, Valve Tubes: adım 1, 2 resimden 1. Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement, Valve Tubes: adım 1, 2 resimden 2.
    • Remove the eight 6 mm screws using the Phillips #1 screwdriver.
    • Remove the bottom cover.
  2. Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement: adım 2, 1 resimden 1.
    • Remove the three 6 mm screws with the Phillips #1 screwdriver.
    • Remove the plastic cover.
  3. Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement: adım 3, 1 resimden 1.
    • Detach the valve tubes from the valve by squeezing the pins and pulling them away from the valve.
  4. Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement: adım 4, 1 resimden 1.
    • Detach the valve tubes from the device by pinching the pins and sliding the valve tubes off.
Sonuç
Naser Aldousari
310 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G69, Cagle Fall 2017 USF Tampa, Team S13-G69, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S13G69
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 913
