Ana içeriğe geç
Ninja Coffee Bar® Single-Serve System Water Regulating Valve Replacement
Neye ihtiyacın var
  1. Ninja Coffee Bar® Single-Serve System Water Regulating Valve Replacement, Valve: adım 1, 1 resimden 1.
    • Unscrew eight 6mm screws with Phillips head #1 screwdriver
    • Remove bottom cover
  2. Ninja Coffee Bar® Single-Serve System Water Regulating Valve Replacement: adım 2, 1 resimden 1.
    • Unscrew three 6mm screws with Phillips head #1 screwdriver
    • Remover tube protection plate
  3. Ninja Coffee Bar® Single-Serve System Water Regulating Valve Replacement: adım 3, 2 resimden 1. Ninja Coffee Bar® Single-Serve System Water Regulating Valve Replacement: adım 3, 2 resimden 2.
    • Detach valve tubes from valve by squeezing pins and pull tubes away from valve
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Naser Aldousari
310 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G69, Cagle Fall 2017 USF Tampa, Team S13-G69, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S13G69
4 Üyeler
2 Yorum
Where can I get the replacement water valve?
Mark Peters - Yanıt
Anyone have a source for the valve?
ErrorCode67 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 1,954
