Ana içeriğe geç
Ninja Coffee Bar® Single-Serve System Water Reservoir Hanger Replacement
Neye ihtiyacın var
  1. Ninja Coffee Bar® Single-Serve System Water Reservoir Hanger Replacement, Water Reservoir Clip: adım 1, 2 resimden 1. Ninja Coffee Bar® Single-Serve System Water Reservoir Hanger Replacement, Water Reservoir Clip: adım 1, 2 resimden 2.
    • Remove single 6mm #1 Phillips head screw from the side of the unit and four 6mm screws from under the basket area.
  2. Ninja Coffee Bar® Single-Serve System Water Reservoir Hanger Replacement: adım 2, 2 resimden 1. Ninja Coffee Bar® Single-Serve System Water Reservoir Hanger Replacement: adım 2, 2 resimden 2.
    • Gently pry the upper panel up from the unit.
  3. Ninja Coffee Bar® Single-Serve System Water Reservoir Hanger Replacement: adım 3, 1 resimden 1.
    • Inside the panel, remove the two 6mm #1 Phillips head screws. Remove and replace water reservoir clip as necessary.
Sonuç
CJ Berg
444 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 üyesi
UMASSD-GULBRANDSEN-F18S5G4
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 826
