Ana içeriğe geç
Ninja Coffee Bar CF080 Brewer Head Replacement
Neye ihtiyacın var
  1. Ninja Coffee Bar CF080 Brewer Head Replacement, Brewer Head: adım 1, 1 resimden 1.
    • Face the coffee machine in front of you.
    • Make sure that the coffee machine is unplugged.
    • Remove the glass carafe as it will not be needed.
  2. Ninja Coffee Bar CF080 Brewer Head Replacement: adım 2, 1 resimden 1.
    • Firmly grab the tab sticking out from the head of the brewer.
  3. Ninja Coffee Bar CF080 Brewer Head Replacement: adım 3, 3 resimden 1. Ninja Coffee Bar CF080 Brewer Head Replacement: adım 3, 3 resimden 2. Ninja Coffee Bar CF080 Brewer Head Replacement: adım 3, 3 resimden 3.
    • With little force, pull the tab of the brewer head in reverse direction.
  4. Ninja Coffee Bar CF080 Brewer Head Replacement: adım 4, 1 resimden 1.
    • Slide off the head in the direction away from the machine.
    • If the head does not come off smoothly by sliding, give a firm tug in the same direction.
  5. Ninja Coffee Bar CF080 Brewer Head Replacement: adım 5, 3 resimden 1. Ninja Coffee Bar CF080 Brewer Head Replacement: adım 5, 3 resimden 2. Ninja Coffee Bar CF080 Brewer Head Replacement: adım 5, 3 resimden 3.
    • Hold the head in the same position and lift it forward until the Ninja is facing upward toward the ceiling.
  6. Ninja Coffee Bar CF080 Brewer Head Replacement: adım 6, 1 resimden 1.
    • Now the brewer head is positioned to where you can seeing the bottom.
  7. Ninja Coffee Bar CF080 Brewer Head Replacement: adım 7, 2 resimden 1. Ninja Coffee Bar CF080 Brewer Head Replacement: adım 7, 2 resimden 2.
    • Remove the screw with a Phillips #1 screwdriver.
    • Use Phillips #1 screwdriver.
    • Along will come a small black screw cover and spring
  8. Ninja Coffee Bar CF080 Brewer Head Replacement: adım 8, 1 resimden 1.
    • Twist the black lid on top clockwise until it is completely detached.
  9. Ninja Coffee Bar CF080 Brewer Head Replacement: adım 9, 1 resimden 1.
    • With the black upper lid detached, a smaller black cover can be removed without effort.
  10. Ninja Coffee Bar CF080 Brewer Head Replacement: adım 10, 2 resimden 1. Ninja Coffee Bar CF080 Brewer Head Replacement: adım 10, 2 resimden 2.
    • Remove the 6 screws from the seal with a Phillips #1 screwdriver.
  11. Ninja Coffee Bar CF080 Brewer Head Replacement: adım 11, 1 resimden 1.
    • Once all screws are detached from the brewer head, it will be separated into two pieces leaving the filter.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Elizabeth Nguyen
416 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S1-G1, Bruce Fall 2017 CSU Fullerton, Team S1-G1, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S1G1
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 991
