Ana içeriğe geç
Ninja Coffee Bar CF080 Control Panel Replacement
Neye ihtiyacın var
  1. Ninja Coffee Bar CF080 Control Panel Replacement, Heated Plate: adım 1, 1 resimden 1.
    • Face the machine bottom towards you.
  2. Ninja Coffee Bar CF080 Control Panel Replacement: adım 2, 2 resimden 1. Ninja Coffee Bar CF080 Control Panel Replacement: adım 2, 2 resimden 2.
    • Unscrew six 0.6cm screws by holding the bottom board with Torx #10 screwdriver to remove the board.
    • Unscrew one 0.6 cm screw with PH1 screwdriver to remove the board.
  3. Ninja Coffee Bar CF080 Control Panel Replacement: adım 3, 3 resimden 1. Ninja Coffee Bar CF080 Control Panel Replacement: adım 3, 3 resimden 2. Ninja Coffee Bar CF080 Control Panel Replacement: adım 3, 3 resimden 3.
    • With moderate force remove and place the "plastic opening tool" between the divide in order to remove the bottom board.
  4. Ninja Coffee Bar CF080 Control Panel Replacement: adım 4, 3 resimden 1. Ninja Coffee Bar CF080 Control Panel Replacement: adım 4, 3 resimden 2. Ninja Coffee Bar CF080 Control Panel Replacement: adım 4, 3 resimden 3.
    • Remove the bottom board with moderate force.
  5. Ninja Coffee Bar CF080 Control Panel Replacement: adım 5, 1 resimden 1.
    • Unscrew eight 0.6cm sized screws with Phillips #1 screwdriver, holding the silver secures on the sides of the heated plate.
    • Four screws on each side, two silver secures to remove the securers, located on the sliver bar holding the heated plate (one on each end).
  6. Ninja Coffee Bar CF080 Control Panel Replacement: adım 6, 1 resimden 1.
    • Unscrew two 0.6cm sized screws Phillips #1 screwdriver.
    • The silver bar will fall off once screws are removed.
  7. Ninja Coffee Bar CF080 Control Panel Replacement: adım 7, 2 resimden 1. Ninja Coffee Bar CF080 Control Panel Replacement: adım 7, 2 resimden 2.
    • Remove the heated plate from the machine with easy glide.
  8. Ninja Coffee Bar CF080 Control Panel Replacement, Power Module: adım 8, 3 resimden 1. Ninja Coffee Bar CF080 Control Panel Replacement, Power Module: adım 8, 3 resimden 2. Ninja Coffee Bar CF080 Control Panel Replacement, Power Module: adım 8, 3 resimden 3.
    • Remove the nine 0.5cm screws with Phillips #2 screwdriver.
    • Some screws are harder to see due to how deep the holes are.
    • Recommend using Extender 4 with Phillips #2 screwdriver to help unscrew the screws within the deep holes of the machine.
  9. Ninja Coffee Bar CF080 Control Panel Replacement: adım 9, 2 resimden 1. Ninja Coffee Bar CF080 Control Panel Replacement: adım 9, 2 resimden 2.
    • Remove the two 0.6cm with Phillips #2 screwdriver.
  10. Ninja Coffee Bar CF080 Control Panel Replacement: adım 10, 3 resimden 1. Ninja Coffee Bar CF080 Control Panel Replacement: adım 10, 3 resimden 2. Ninja Coffee Bar CF080 Control Panel Replacement: adım 10, 3 resimden 3.
    • Detach various colored cords from one another, using both hands to place thumb and index finger to hold each grip then separate by pulling with the degree of force.
    • There with be 1 blue, 1 black, 1 red and 2 white.
  11. Ninja Coffee Bar CF080 Control Panel Replacement: adım 11, 2 resimden 1. Ninja Coffee Bar CF080 Control Panel Replacement: adım 11, 2 resimden 2.
    • Remove the black board by maneuvering it through the cords.
  12. Ninja Coffee Bar CF080 Control Panel Replacement: adım 12, 3 resimden 1. Ninja Coffee Bar CF080 Control Panel Replacement: adım 12, 3 resimden 2. Ninja Coffee Bar CF080 Control Panel Replacement: adım 12, 3 resimden 3.
    • Grip the bottom end of the panel and pull it towards you to remove the module from the machine.
  13. Ninja Coffee Bar CF080 Control Panel Replacement: adım 13, 2 resimden 1. Ninja Coffee Bar CF080 Control Panel Replacement: adım 13, 2 resimden 2.
    • Remove the three 0.6cm screws with Phillips #1 screwdriver.
    • They are in the black holes, 1 at the top and two at the bottom.
  14. Ninja Coffee Bar CF080 Control Panel Replacement: adım 14, 1 resimden 1.
    • Remove the black board attached to the module.
  15. Ninja Coffee Bar CF080 Control Panel Replacement, Control Panel: adım 15, 2 resimden 1. Ninja Coffee Bar CF080 Control Panel Replacement, Control Panel: adım 15, 2 resimden 2.
    • Unscrew four 1.2cm screws with Phillips #2 screwdriver.
  16. Ninja Coffee Bar CF080 Control Panel Replacement: adım 16, 2 resimden 1. Ninja Coffee Bar CF080 Control Panel Replacement: adım 16, 2 resimden 2.
    • Carefully remove the control panel from the control module.
  17. Ninja Coffee Bar CF080 Control Panel Replacement: adım 17, 1 resimden 1.
    • Left with the control module.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jan Chen
235 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S1-G1, Bruce Fall 2017 CSU Fullerton, Team S1-G1, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S1G1
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
This is great an all, but WHERE do you get the new control board?!? Without it this is worthless...
madmikey - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 1,869
