Ana içeriğe geç
Ninja Coffee Bar CF080 Heated Plate Replacement
Neye ihtiyacın var
  1. Ninja Coffee Bar CF080 Heated Plate Replacement, Heated Plate: adım 1, 1 resimden 1.
    • Face the machine bottom towards you.
  2. Ninja Coffee Bar CF080 Heated Plate Replacement: adım 2, 2 resimden 1. Ninja Coffee Bar CF080 Heated Plate Replacement: adım 2, 2 resimden 2.
    • Unscrew six 0.6cm screws by holding the bottom board with Torx #10 screwdriver to remove the board.
    • Unscrew one 0.6 cm screw with PH1 screwdriver to remove the board.
  3. Ninja Coffee Bar CF080 Heated Plate Replacement: adım 3, 3 resimden 1. Ninja Coffee Bar CF080 Heated Plate Replacement: adım 3, 3 resimden 2. Ninja Coffee Bar CF080 Heated Plate Replacement: adım 3, 3 resimden 3.
    • With moderate force remove and place the "plastic opening tool" between the divide in order to remove the bottom board.
  4. Ninja Coffee Bar CF080 Heated Plate Replacement: adım 4, 3 resimden 1. Ninja Coffee Bar CF080 Heated Plate Replacement: adım 4, 3 resimden 2. Ninja Coffee Bar CF080 Heated Plate Replacement: adım 4, 3 resimden 3.
    • Remove the bottom board with moderate force.
  5. Ninja Coffee Bar CF080 Heated Plate Replacement: adım 5, 1 resimden 1.
    • Unscrew eight 0.6cm sized screws with Phillips #1 screwdriver, holding the silver secures on the sides of the heated plate.
    • Four screws on each side, two silver secures to remove the securers, located on the sliver bar holding the heated plate (one on each end).
  6. Ninja Coffee Bar CF080 Heated Plate Replacement: adım 6, 1 resimden 1.
    • Unscrew two 0.6cm sized screws Phillips #1 screwdriver.
    • The silver bar will fall off once screws are removed.
  7. Ninja Coffee Bar CF080 Heated Plate Replacement: adım 7, 2 resimden 1. Ninja Coffee Bar CF080 Heated Plate Replacement: adım 7, 2 resimden 2.
    • Remove the heated plate from the machine with easy glide.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Elizabeth Nguyen
416 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S1-G1, Bruce Fall 2017 CSU Fullerton, Team S1-G1, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S1G1
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Where do you get a replacement plate at?
Timothy Sick - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 798
