Ana içeriğe geç
Ninja Coffee Bar CF086 Water Heating Element Replacement
Neye ihtiyacın var
  1. Ninja Coffee Bar CF086 Water Heating Element Replacement, Water Heating Element: adım 1, 2 resimden 1. Ninja Coffee Bar CF086 Water Heating Element Replacement, Water Heating Element: adım 1, 2 resimden 2.
    • Make sure the Ninja Coffee Bar is unplugged and that you have a dry, clean workspace for this task.
    • Remove the carafe and water reservoir and set them aside.
  2. Ninja Coffee Bar CF086 Water Heating Element Replacement: adım 2, 1 resimden 1.
    • Unscrew the T-10 screws from the bottom cover of the machine, and remove that bottom cover.
  3. Ninja Coffee Bar CF086 Water Heating Element Replacement: adım 3, 1 resimden 1.
    • Unscrew and remove the heating plate layer. This will expose the internal workings of the machine.
  4. Ninja Coffee Bar CF086 Water Heating Element Replacement: adım 4, 1 resimden 1.
    • Locate the water heating element in the interior of your coffee maker.
    • Unscrew the two indicated J1S1 screws at the base of the water heating element.
  5. Ninja Coffee Bar CF086 Water Heating Element Replacement: adım 5, 1 resimden 1.
    • Unscrew and remove the remaining J1S1 screws that secure the water heating element to the interior of the device.
  6. Ninja Coffee Bar CF086 Water Heating Element Replacement: adım 6, 3 resimden 1. Ninja Coffee Bar CF086 Water Heating Element Replacement: adım 6, 3 resimden 2. Ninja Coffee Bar CF086 Water Heating Element Replacement: adım 6, 3 resimden 3.
    • Grasp and remove the clamp securing the tube that feeds into the base of the water heating element.
    • Detach the tube from the water heating element.
  7. Ninja Coffee Bar CF086 Water Heating Element Replacement: adım 7, 2 resimden 1. Ninja Coffee Bar CF086 Water Heating Element Replacement: adım 7, 2 resimden 2.
    • Locate the coated wire that feeds into the side of the water heating element. Remove this wire.
  8. Ninja Coffee Bar CF086 Water Heating Element Replacement: adım 8, 2 resimden 1. Ninja Coffee Bar CF086 Water Heating Element Replacement: adım 8, 2 resimden 2.
    • Locate the two wires leading out from the water heating element that feed into crimp connectors.
    • Using side cutters, sever these wires near the crimp connectors.
    • Use the side cutters to cut the remaining wires that feed into the crimp connectors from the coffee machine.
  9. Ninja Coffee Bar CF086 Water Heating Element Replacement: adım 9, 2 resimden 1. Ninja Coffee Bar CF086 Water Heating Element Replacement: adım 9, 2 resimden 2.
    • Squeeze and remove the clamp that secures the main tube feeding into the water heating element. Remove that tube.
    • Remove the water heating element.
  10. Ninja Coffee Bar CF086 Water Heating Element Replacement: adım 10, 3 resimden 1. Ninja Coffee Bar CF086 Water Heating Element Replacement: adım 10, 3 resimden 2. Ninja Coffee Bar CF086 Water Heating Element Replacement: adım 10, 3 resimden 3.
    • Using wire strippers, strip the cut wires from your coffee machine near their cut ends to expose 2 cm of metal conductor from each.
    • Use a similar procedure to strip the wires from your replacement heating element. Using wire strippers, expose 2 cm of metal conductor from the ends of the wires.
  11. Ninja Coffee Bar CF086 Water Heating Element Replacement: adım 11, 1 resimden 1.
    • Prepare two crimp connectors by filling them with dielectric grease.
    • Use a crimp connector to connect a stripped end of the wire leading from the replacement heating element to the stripped end of the corresponding wire from the coffee maker.
    • Using a second crimp connector, repeat for the remaining pair of stripped wires.
    • Using the appropriate crimping tool, crimp the connectors.
Sonuç
To finish reassembling your device, follow steps 2-7 in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
David Ton
630 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G5, Thompson Fall 2017 USF Tampa, Team S1-G5, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S1G5
4 Üyeler
2 Yorum
Where is the heating element available for sale.
ausbinp - Yanıt
I need a element for a CM401 model, any help?. gene@wholedamarea.com
Lester Bouler - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 42
Her zaman: 4,271
