Giriş
The water heating element is a resistive coiled wire that boils the water used in brews. This guide describes how to replace the heating element.
Neye ihtiyacın var
Using wire strippers, strip the cut wires from your coffee machine near their cut ends to expose 2 cm of metal conductor from each.
Use a similar procedure to strip the wires from your replacement heating element. Using wire strippers, expose 2 cm of metal conductor from the ends of the wires.
Prepare two crimp connectors by filling them with dielectric grease.
Use a crimp connector to connect a stripped end of the wire leading from the replacement heating element to the stripped end of the corresponding wire from the coffee maker.
Using a second crimp connector, repeat for the remaining pair of stripped wires.
Using the appropriate crimping tool, crimp the connectors.
To finish reassembling your device, follow steps 2-7 in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
I need a element for a CM401 model, any help?. gene@wholedamarea.com
