Giriş
The outer bowl release button spring allows the Ninja Creami to lock and release the bowl securely during operation. If the button feels stuck, loose, or no longer pops back into place, the spring may be worn or displaced. This guide will show you how to safely inspect, remove, and replace the spring. Always unplug the device before starting to avoid injury.
Neye ihtiyacın var
Remove the thirteen 14.0 mm Phillips screws from the bottom platform.
Pry and remove the bottom platform
Sonuç
