Ana içeriğe geç
Ninja Creami Rotating Shaft Replacement
Neye ihtiyacın var
  1. Ninja Creami Rotating Shaft Replacement, Outer Shell: adım 1, 2 resimden 1. Ninja Creami Rotating Shaft Replacement, Outer Shell: adım 1, 2 resimden 2.
    • Use an opening tool to gently lift and remove the grey cover from the top of the main piece.
    • Start at one edge and work your way around to avoid cracking the housing.
  2. Ninja Creami Rotating Shaft Replacement: adım 2, 3 resimden 1. Ninja Creami Rotating Shaft Replacement: adım 2, 3 resimden 2. Ninja Creami Rotating Shaft Replacement: adım 2, 3 resimden 3.
    • Remove the ten 13.6 mm Phillips screws from the perimeter of the outer cover.
    • Lift the black plastic cover straight up and off.
  3. Ninja Creami Rotating Shaft Replacement: adım 3, 2 resimden 1. Ninja Creami Rotating Shaft Replacement: adım 3, 2 resimden 2.
    • Remove the four 12.2 mm Phillips screws from the black plastic cover.
  4. Ninja Creami Rotating Shaft Replacement, Daughterboard: adım 4, 2 resimden 1. Ninja Creami Rotating Shaft Replacement, Daughterboard: adım 4, 2 resimden 2.
    • Disconnect the daughterboard's motherboard connector.
    • Remove the daughter board.
  5. Ninja Creami Rotating Shaft Replacement, Rotating Shaft: adım 5, 2 resimden 1. Ninja Creami Rotating Shaft Replacement, Rotating Shaft: adım 5, 2 resimden 2.
    • Disconnect the black connector from motherboard.
  6. Ninja Creami Rotating Shaft Replacement: adım 6, 3 resimden 1. Ninja Creami Rotating Shaft Replacement: adım 6, 3 resimden 2. Ninja Creami Rotating Shaft Replacement: adım 6, 3 resimden 3.
    • Remove the top of the gear housing while holding the bottom in place.
  7. Ninja Creami Rotating Shaft Replacement: adım 7, 3 resimden 1. Ninja Creami Rotating Shaft Replacement: adım 7, 3 resimden 2. Ninja Creami Rotating Shaft Replacement: adım 7, 3 resimden 3.
    • Hold the bottom of the gear housing above the shafts that it is on and pull out the rotating shaft.
Sonuç
Karlee B
667 İtibar
6 adet Kılavuz yazıldı
4Kılavuz Yorumları
Is there a replacement shaft anywhere online I could buy?
Daniel Jovel - Yanıt
Also interested, where can I buy a rotating shaft?
Tozapid - Yanıt
Also interested in purchasing a rotating shaft...
Jim Campbell - Yanıt
Came here, anywere to but it?
Leonardo Morales - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 79
Son 30 gün: 309
Her zaman: 1,840
