Ana içeriğe geç
Ninja Foodi DZ401 Heating Element Replacement
Neye ihtiyacın var
    1. Ninja Foodi DZ401 Heating Element Replacement, Top Cover: adım 1, 3 resimden 1. Ninja Foodi DZ401 Heating Element Replacement, Top Cover: adım 1, 3 resimden 2. Ninja Foodi DZ401 Heating Element Replacement, Top Cover: adım 1, 3 resimden 3.
      • Position the air fryer so that the front is facing you and the top is accessible.
      • Using opening picks and a metal spudger, pry open the silver ring on the front, right corner.
      • Place an opening pick on the left side of the corner to hold the ring away from the cover.
      • Slide the metal spudger underneath the silver ring. When you find a notch, place the metal spudger next to the notch and pry up to release it.
      • This process requires a significant amount of force to be applied to the silver ring and top cover of the air fryer. It may result in damage to both tools and the air fryer cover.
      FixBot'a Sor
      Yorum Ekle
    2. Ninja Foodi DZ401 Heating Element Replacement: adım 2, 1 resimden 1.
      • Using a metal spudger, pry open the plastic top cover by inserting into the slots and pushing up on the tabs.
      • There are three openings on the front, one on each side, and four on the back of the unit.
      • The metal spudger may scratch or damage the cover if care is not taken.
      FixBot'a Sor
      Yorum Ekle
    1. Ninja Foodi DZ401 Heating Element Replacement, Outer Casing: adım 3, 1 resimden 1.
      • Rotate the air fryer so that the back of the air fryer is facing down and the base is facing you.
      FixBot'a Sor
      Yorum Ekle
    2. Ninja Foodi DZ401 Heating Element Replacement: adım 4, 3 resimden 1. Ninja Foodi DZ401 Heating Element Replacement: adım 4, 3 resimden 2. Ninja Foodi DZ401 Heating Element Replacement: adım 4, 3 resimden 3.
      • Remove the ten 15 mm screws from the bottom of the air fryer using a Phillips #3 screwdriver.
      • Remove the power cord cover.
      • Remove the two 16.7 mm power cord bracket screws using a Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Ninja Foodi DZ401 Heating Element Replacement: adım 5, 1 resimden 1.
      • Rotate the air fryer so that the rear fan vents are accessible.
      FixBot'a Sor
      Yorum Ekle
    4. Ninja Foodi DZ401 Heating Element Replacement: adım 6, 2 resimden 1. Ninja Foodi DZ401 Heating Element Replacement: adım 6, 2 resimden 2.
      • Remove the four 11.1 mm screws from each vent using a Phillips #1 screwdriver.
      • Remove both vents.
      FixBot'a Sor
      Yorum Ekle
    5. Ninja Foodi DZ401 Heating Element Replacement: adım 7, 3 resimden 1. Ninja Foodi DZ401 Heating Element Replacement: adım 7, 3 resimden 2. Ninja Foodi DZ401 Heating Element Replacement: adım 7, 3 resimden 3.
      • Carefully pull the outer casing up from the back.
      • Disconnect the front display cable from the motherboard.
      • Fully remove the outer casing.
      FixBot'a Sor
      Yorum Ekle
    1. Ninja Foodi DZ401 Heating Element Replacement, Heating Element: adım 8, 1 resimden 1.
      • Rotate the air fryer so that the front is facing you and the top is accessible.
      FixBot'a Sor
      Yorum Ekle
    2. Ninja Foodi DZ401 Heating Element Replacement: adım 9, 3 resimden 1. Ninja Foodi DZ401 Heating Element Replacement: adım 9, 3 resimden 2. Ninja Foodi DZ401 Heating Element Replacement: adım 9, 3 resimden 3.
      • Locate the brown/orange wire bundle at the front of the air fryer and extract it.
      • Locate the white wire bundle at the rear of the air fryer and extract it.
      • Using pliers, uncrimp and remove the plastic wire caps.
      • Carefully separate the wires.
      • The wires may be sharp. Use pliers to increase safety.
      FixBot'a Sor
      Yorum Ekle
    3. Ninja Foodi DZ401 Heating Element Replacement: adım 10, 2 resimden 1. Ninja Foodi DZ401 Heating Element Replacement: adım 10, 2 resimden 2.
      • Remove the white wire from the three guiding hooks.
      FixBot'a Sor
      Yorum Ekle
    4. Ninja Foodi DZ401 Heating Element Replacement: adım 11, 3 resimden 1. Ninja Foodi DZ401 Heating Element Replacement: adım 11, 3 resimden 2. Ninja Foodi DZ401 Heating Element Replacement: adım 11, 3 resimden 3.
      • Remove the single 10.9 mm screw from the front of the heating element using a Phillips #2 screwdriver.
      • Gently pull down the heating element from the front.
      • The element wires should come out of their respective holes.
      • Unhook the heating element from the rear hook.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6Kılavuz Yorumları
is it possible to start at step 11 to lower the heating coil a little bit to get inbehind the coil to really deep clean the top area? No tlooking to detach but clean.
Jacob Feht - Yanıt Paylaş
You are welcome to try that. If I remember correctly, it may be difficult to do so because of the awkward angle and wires attached. You may be able to lower it slightly but I am unable to confirm that. It is unfortunately a very frustrating device to take apart as you often have to disassemble the whole device, specifically the outer shell and lower base to get what you need.
Preston Dyess - Yanıt Paylaş
Where do you get the replacement heating element from? Is it an aftermarket part or OEM?
Alan Smithee - Yanıt Paylaş
Just want to start of by saying thank you for these guides. Very helpful. I just want to add that there is a step missing between Step 5 & 7. Step 5 shows the top cover still on but then in Step 7 it’s off. But step 2 shows how to remove the top cover. Also to take the casing off, you have to remove the 4 screws located underneath the top cover. Took me around 20 mins to work out that to take the outer casing off these 4 screws need to come out first. Couldn’t believe how easy the cover came off after removing the screws. 😂
Mifo J - Yanıt Paylaş
Whatever about putting in a new element. Where do you get them from? Anyone know how much they are?
Angelin Susan Perry - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 65
Son 30 gün: 333
Her zaman: 8,123
