Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Ninja Foodi SP101 Control Panel Replacement
Neye ihtiyacın var
    1. Ninja Foodi SP101 Control Panel Replacement, Feet: adım 1, 2 resimden 1. Ninja Foodi SP101 Control Panel Replacement, Feet: adım 1, 2 resimden 2.
      • Use a TR10 screwdriver to remove the four 11mm screws holding the black lever bar in place.
      FixBot'a Sor
      Yorum Ekle
    2. Ninja Foodi SP101 Control Panel Replacement: adım 2, 1 resimden 1.
      • Remove the black lever bar.
      FixBot'a Sor
      Yorum Ekle
    1. Ninja Foodi SP101 Control Panel Replacement, Side Panels: adım 3, 1 resimden 1.
      • Use a Phillips #1 screwdriver to remove the three 8mm screws on each side of the back panel.
      FixBot'a Sor
      Yorum Ekle
    2. Ninja Foodi SP101 Control Panel Replacement: adım 4, 2 resimden 1. Ninja Foodi SP101 Control Panel Replacement: adım 4, 2 resimden 2.
      • Flip the device upside down and open the bottom panel.
      • Remove the 3 x philips #1 screws along the top edge of the interior using a screwdriver. The Bottom 2 do not have to be removed.
      FixBot'a Sor
      Yorum Ekle
    3. Ninja Foodi SP101 Control Panel Replacement: adım 5, 3 resimden 1. Ninja Foodi SP101 Control Panel Replacement: adım 5, 3 resimden 2. Ninja Foodi SP101 Control Panel Replacement: adım 5, 3 resimden 3.
      • Remove the control side panel. To remove it, push forward towards then front control panel to release the tabs out of the main body. Fold away the side panel when the tabs have visually released from their slots in the main body.
      FixBot'a Sor
      Yorum Ekle
    4. Ninja Foodi SP101 Control Panel Replacement: adım 6, 2 resimden 1. Ninja Foodi SP101 Control Panel Replacement: adım 6, 2 resimden 2.
      • Lift the handle and pull the side panel out.
      • Remove the handle side panel.
      FixBot'a Sor
      Yorum Ekle
    1. Ninja Foodi SP101 Control Panel Replacement, Control Panel: adım 7, 1 resimden 1.
      • Remove the 10mm screw using the Phillips #1 screwdriver.
      • This screw connects the motherboard to the motor.
      FixBot'a Sor
      Yorum Ekle
    2. Ninja Foodi SP101 Control Panel Replacement: adım 8, 3 resimden 1. Ninja Foodi SP101 Control Panel Replacement: adım 8, 3 resimden 2. Ninja Foodi SP101 Control Panel Replacement: adım 8, 3 resimden 3.
      • Locate the control panel.
      • Slide the top panel outwards and to the right.
      FixBot'a Sor
      Yorum Ekle
    3. Ninja Foodi SP101 Control Panel Replacement: adım 9, 1 resimden 1.
      • Remove the three 8 mm screws with the Phillips #1 screwdriver.
      • These are located on the control panel side that was facing inward.
      FixBot'a Sor
      Yorum Ekle
    4. Ninja Foodi SP101 Control Panel Replacement: adım 10, 2 resimden 1. Ninja Foodi SP101 Control Panel Replacement: adım 10, 2 resimden 2.
      • Unclip the wires from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. Ninja Foodi SP101 Control Panel Replacement: adım 11, 1 resimden 1.
      • Remove the control panel.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Griffin Peterson
652 İtibar
6 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 32
Son 30 gün: 144
Her zaman: 2,999
