Giriş
The control panel on your Ninja Foodi SP101 is the only way to interact with the oven. It is responsible for controlling the temperature, the mode, and the remaining time to cook. A non-functioning control panel prevents the user from interacting with the device.
Neye ihtiyacın var
Use a TR10 screwdriver to remove the four 11mm screws holding the black lever bar in place.
Use a Phillips #1 screwdriver to remove the three 8mm screws on each side of the back panel.
