Giriş
In the Ninja Foodi SP101, the cooling fan is a key part to ensure the unit returns to room temperature after use. Before starting this guide, ensure that the Foodi is disconnected from power and completely cool.
Neye ihtiyacın var
Use a TR10 screwdriver to remove the four 11mm screws holding the black lever bar in place.
Use a Phillips #1 screwdriver to remove the three 8mm screws on each side of the back panel.
2 farklı kişi bu kılavuzu tamamladı.
