Giriş
In this guide, we are removing the fan from the base of the Ninja.
Neye ihtiyacın var
Take out the three 15 mm Phillips #1 screws.
Remove the 15mm T10 screw.
Remove the central 15 mm length screw, you must hold the fan in place and use a flat head screw driver, twisting counterclockwise.
3 farklı kişi bu kılavuzu tamamladı.
