Ana içeriğe geç
Ninja Kitchen System Pulse Motor Replacement
Neye ihtiyacın var
    1. Ninja Kitchen System Pulse Motor Replacement, Base Disassembly: adım 1, 1 resimden 1.
      • Take out the three 15 mm Phillips #1 screws.
      • Remove the 15mm T10 screw.
      • Place the 4 screws on the magnetic mat.
      FixBot'a Sor
      Yorum Ekle
    2. Ninja Kitchen System Pulse Motor Replacement: adım 2, 1 resimden 1.
      • Remove the gray base by lifting upwards and placing to the side.
      FixBot'a Sor
      Yorum Ekle
    1. Ninja Kitchen System Pulse Motor Replacement, Motor: adım 3, 1 resimden 1.
      • Remove the three 15 mm Phillips #1 screws.
      • Place screws on magnetic mat.
      FixBot'a Sor
      Yorum Ekle
    2. Ninja Kitchen System Pulse Motor Replacement: adım 4, 1 resimden 1.
      • Remove the motor by gently lifting up. Be careful with the cords, as they may be tangled.
      • This is the entire motor for the Ninja. If you have access to a spare motor, simply swap out the motors.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
DJ
131 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 15-1, Remmell Spring 2016 USF Tampa, Team 15-1, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S15G1
3 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Dear sir my ninga kitchen system 1100 (blender machine) motor rod is broken i need help to replace it where i can get the rod or repair shop near me thank you
Noman - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 50
Her zaman: 4,903
