Ana içeriğe geç
Ninja Mega Kitchen System BL770 Circuit Base Replacement
Neye ihtiyacın var
  1. Ninja Mega Kitchen System BL770 Circuit Base Replacement, Circuit Base: adım 1, 2 resimden 1. Ninja Mega Kitchen System BL770 Circuit Base Replacement, Circuit Base: adım 1, 2 resimden 2.
    • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
    • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
  2. Ninja Mega Kitchen System BL770 Circuit Base Replacement: adım 2, 1 resimden 1.
    • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
  3. Ninja Mega Kitchen System BL770 Circuit Base Replacement: adım 3, 3 resimden 1. Ninja Mega Kitchen System BL770 Circuit Base Replacement: adım 3, 3 resimden 2. Ninja Mega Kitchen System BL770 Circuit Base Replacement: adım 3, 3 resimden 3.
    • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
    • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
    • Carefully lift the base up from the rest of the blender.
  4. Ninja Mega Kitchen System BL770 Circuit Base Replacement: adım 4, 1 resimden 1.
    • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Hey Tommee where can I get a circuit board for the ninja bl 773.
Bhesham Sochan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 1,366
