Giriş
This will work as a prerequisite guide for all other guides. This helps us break down the device into the main base layer.
Neye ihtiyacın var
Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
Bir başkası bu kılavuzu tamamladı.
