Ana içeriğe geç
Ninja Mega Kitchen System BL770 Cooling Fan Replacement
Neye ihtiyacın var
  1. Ninja Mega Kitchen System BL770 Cooling Fan Replacement, Circuit Base: adım 1, 2 resimden 1. Ninja Mega Kitchen System BL770 Cooling Fan Replacement, Circuit Base: adım 1, 2 resimden 2.
    • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
    • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
  2. Ninja Mega Kitchen System BL770 Cooling Fan Replacement: adım 2, 1 resimden 1.
    • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
  3. Ninja Mega Kitchen System BL770 Cooling Fan Replacement: adım 3, 3 resimden 1. Ninja Mega Kitchen System BL770 Cooling Fan Replacement: adım 3, 3 resimden 2. Ninja Mega Kitchen System BL770 Cooling Fan Replacement: adım 3, 3 resimden 3.
    • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
    • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
    • Carefully lift the base up from the rest of the blender.
  4. Ninja Mega Kitchen System BL770 Cooling Fan Replacement: adım 4, 1 resimden 1.
    • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
  5. Ninja Mega Kitchen System BL770 Cooling Fan Replacement, Cooling Fan: adım 5, 2 resimden 1. Ninja Mega Kitchen System BL770 Cooling Fan Replacement, Cooling Fan: adım 5, 2 resimden 2.
    • Using caution, hold the fan steady and use a wrench or pliers to remove the nut securing the fan.
    • Loosen the washer with a flathead screwdriver, then remove the fan and replace with a new one.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 18
Her zaman: 767
