Ana içeriğe geç
Nintendo 2DS Battery Replacement
Neye ihtiyacın var
  1. Nintendo 2DS Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the two Phillips captive screws securing the upper rear panel.
    • The captive screws will not completely detach from the back panel.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo 2DS Battery Replacement: adım 2, 2 resimden 1. Nintendo 2DS Battery Replacement: adım 2, 2 resimden 2.
    • Hinge the upper rear panel upwards and outwards to remove it.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo 2DS Battery Replacement: adım 3, 3 resimden 1. Nintendo 2DS Battery Replacement: adım 3, 3 resimden 2. Nintendo 2DS Battery Replacement: adım 3, 3 resimden 3.
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
    FixBot'a Sor
    Yorum Ekle
Sonuç
46 farklı kişi bu kılavuzu tamamladı.
Fina Beauchamp
3.388 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 70-1, Forte Winter 2015 Cal Poly, Team 70-1, Forte Winter 2015 üyesi
CPSU-FORTE-W15S70G1
4 Üyeler
36 adet Kılavuz yazıldı
7Kılavuz Yorumları
The only thing I was trying to figure out is if the bezel came up with the panel, and it’s not clear from these photos. For the record, it does not.
francis deible - Yanıt Paylaş
This didnt help my problem
Artemy Matveev - Yanıt Paylaş
maybe its because you did not plug the battery correctly matthew
Ludovic Chartrain - Yanıt Paylaş
or maybe its just not working ludovic 🫡
Natalia Rabago - Yanıt Paylaş
Who knows, will the same battery, instead of 1300mah in original, 2000mah in 'fake' works with 2DS?
Anton Kornilov - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 26
Son 7 gün: 191
Son 30 gün: 1,005
Her zaman: 64,281
