Ana içeriğe geç
Nintendo 2DS Battery Replacement
Neye ihtiyacın var
  1. Nintendo 2DS Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the two Phillips captive screws securing the upper rear panel.
    • The captive screws will not completely detach from the back panel.
  2. Nintendo 2DS Battery Replacement: adım 2, 2 resimden 1. Nintendo 2DS Battery Replacement: adım 2, 2 resimden 2.
    • Hinge the upper rear panel upwards and outwards to remove it.
  3. Nintendo 2DS Battery Replacement: adım 3, 3 resimden 1. Nintendo 2DS Battery Replacement: adım 3, 3 resimden 2. Nintendo 2DS Battery Replacement: adım 3, 3 resimden 3.
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
Sonuç
38 farklı kişi bu kılavuzu tamamladı.
Fina Beauchamp
3.150 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 70-1, Forte Winter 2015 Cal Poly, Team 70-1, Forte Winter 2015 üyesi
CPSU-FORTE-W15S70G1
4 Üyeler
35 adet Kılavuz yazıldı
5Kılavuz Yorumları
The only thing I was trying to figure out is if the bezel came up with the panel, and it’s not clear from these photos. For the record, it does not.
francis deible - Yanıt
This didnt help my problem
Artemy Matveev - Yanıt
maybe its because you did not plug the battery correctly matthew
Ludovic Chartrain - Yanıt
or maybe its just not working ludovic 🫡
Natalia Rabago -
Who knows, will the same battery, instead of 1300mah in original, 2000mah in 'fake' works with 2DS?
Anton Kornilov - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 41
Son 7 gün: 201
Son 30 gün: 938
Her zaman: 49,507
