Ana içeriğe geç
Nintendo 2DS Trigger Button Replacement
Neye ihtiyacın var
  1. Nintendo 2DS Trigger Button Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the two Phillips captive screws securing the upper rear panel.
    • The captive screws will not completely detach from the back panel.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo 2DS Trigger Button Replacement: adım 2, 2 resimden 1. Nintendo 2DS Trigger Button Replacement: adım 2, 2 resimden 2.
    • Hinge the upper rear panel upwards and outwards to remove it.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo 2DS Trigger Button Replacement: adım 3, 3 resimden 1. Nintendo 2DS Trigger Button Replacement: adım 3, 3 resimden 2. Nintendo 2DS Trigger Button Replacement: adım 3, 3 resimden 3.
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
    FixBot'a Sor
    Yorum Ekle
  4. Nintendo 2DS Trigger Button Replacement, Rear Panel: adım 4, 1 resimden 1.
    • Remove the ten Phillips screws attaching the rear panel.
    FixBot'a Sor
    Yorum Ekle
  5. Nintendo 2DS Trigger Button Replacement: adım 5, 1 resimden 1.
    • The rear panel is attached to the motherboard by a ribbon cable, so be careful not to lift the rear panel too far from the device.
    • Carefully pull the rear panel straight up from the device.
    FixBot'a Sor
    Yorum Ekle
  6. Nintendo 2DS Trigger Button Replacement: adım 6, 1 resimden 1.
    • Use your fingernail or the flat end of a spudger to flip up the connector securing the ribbon cable to the motherboard
    • Remove the cable from the connector
    • Take the opportunity to remove the Left and Right triggers, they have hinges that may break and springs that may jump away.
    FixBot'a Sor
    Yorum Ekle
  7. Nintendo 2DS Trigger Button Replacement, Remove trigger button: adım 7, 2 resimden 1. Nintendo 2DS Trigger Button Replacement, Remove trigger button: adım 7, 2 resimden 2.
    • The trigger buttons have small springs attached to them, so be careful when removing the buttons from the device.
    • Pull the trigger button away from the device to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
23 farklı kişi bu kılavuzu tamamladı.
Fina Beauchamp
3.383 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 70-1, Forte Winter 2015 Cal Poly, Team 70-1, Forte Winter 2015 üyesi
CPSU-FORTE-W15S70G1
4 Üyeler
36 adet Kılavuz yazıldı
3Kılavuz Yorumları
Nice job! My right button was jammed for at least two years. Now I can finally demolish my friends in Mariokart.
Minecrafter Pig - Yanıt Paylaş
Can’t seem to get the second set of screws to budge at all.
Zom baygal - Yanıt Paylaş
now what????
Karim Eltaib - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 85
Son 30 gün: 314
Her zaman: 35,463
