Ana içeriğe geç
Nintendo 3DS 2015 Battery Replacement
Neye ihtiyacın var
  1. Nintendo 3DS 2015 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo 3DS 2015 Battery Replacement: adım 2, 2 resimden 1. Nintendo 3DS 2015 Battery Replacement: adım 2, 2 resimden 2.
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo 3DS 2015 Battery Replacement: adım 3, 3 resimden 1. Nintendo 3DS 2015 Battery Replacement: adım 3, 3 resimden 2. Nintendo 3DS 2015 Battery Replacement: adım 3, 3 resimden 3.
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Tyler Starr
1.779 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-6, Livingston Fall 2016 Cal Poly, Team 4-6, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S4G6
4 Üyeler
46 adet Kılavuz yazıldı
6Kılavuz Yorumları
The link to the Nintendo store to buy a battery no longer functions.
David Clarke - Yanıt Paylaş
My console has been off and without a battery for months now and I haven't been able to get a replacement battery until very recently, I replaced it just now and the orange led lights on (albeit for a short time) but the console won't turn on. The blue led lights up briefly then goes out again and the console remains off. Could it be something wrong with the console itself rather than the battery? Edit: Should I just leave it plugged in for a while even if the orange led doesn't stay on?
Leon J - Yanıt Paylaş
I solved it by cleaning the contacts, reseating the battery and removing the microSD card. The SD card can then be put back in later
How's the battery life on it so far? I know you just posted 2 days ago, but I was just curious.
Will Reds - Yanıt Paylaş
i bought one of these batteries but it’s slightly smaller than the original battery and and the charge does not last long, maybe 1-2 hours
Jessica V - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 61
Son 30 gün: 294
Her zaman: 12,710
