Ana içeriğe geç
Nintendo 3DS 2015 Circle Pad Replacement
Neye ihtiyacın var
  1. Nintendo 3DS 2015 Circle Pad Replacement, Battery: adım 1, 1 resimden 1.
    • Unscrew the two 3mm Phillips #0 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
  2. Nintendo 3DS 2015 Circle Pad Replacement: adım 2, 2 resimden 1. Nintendo 3DS 2015 Circle Pad Replacement: adım 2, 2 resimden 2.
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
  3. Nintendo 3DS 2015 Circle Pad Replacement: adım 3, 3 resimden 1. Nintendo 3DS 2015 Circle Pad Replacement: adım 3, 3 resimden 2. Nintendo 3DS 2015 Circle Pad Replacement: adım 3, 3 resimden 3.
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
  4. Nintendo 3DS 2015 Circle Pad Replacement, SD Card Reader: adım 4, 1 resimden 1.
    • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
    • The bottom of the SD card reader should slightly pop out after removing the screws.
  5. Nintendo 3DS 2015 Circle Pad Replacement: adım 5, 1 resimden 1.
    • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
    • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
    • Reorient the device so that the power jack faces you.
  6. Nintendo 3DS 2015 Circle Pad Replacement: adım 6, 2 resimden 1. Nintendo 3DS 2015 Circle Pad Replacement: adım 6, 2 resimden 2.
    • Lift the SD card reader gently.
    • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
    • Lift the SD card reader out off of the lower casing.
  7. Nintendo 3DS 2015 Circle Pad Replacement, Lower Case: adım 7, 3 resimden 1. Nintendo 3DS 2015 Circle Pad Replacement, Lower Case: adım 7, 3 resimden 2. Nintendo 3DS 2015 Circle Pad Replacement, Lower Case: adım 7, 3 resimden 3.
    • Reorient the device so that the game slot now faces you.
    • Remove the two rubber bumpers along the top of the device using tweezers.
    • Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
  8. Nintendo 3DS 2015 Circle Pad Replacement: adım 8, 2 resimden 1. Nintendo 3DS 2015 Circle Pad Replacement: adım 8, 2 resimden 2.
    • Lift the top edge of the lower case slightly off on the 3DS.
    • Don't pull the lower casing completely off, you may break those connections. There are ribbon cables that must be disconnected first.
    • Pry the ribbon cable socket under the right trigger using a plastic opening tool.
    • Pry the ribbon cable socket under the infrared receiver cover using a plastic opening tool.
  9. Nintendo 3DS 2015 Circle Pad Replacement: adım 9, 3 resimden 1. Nintendo 3DS 2015 Circle Pad Replacement: adım 9, 3 resimden 2. Nintendo 3DS 2015 Circle Pad Replacement: adım 9, 3 resimden 3.
    • Open the device slowly from its top edge. Be careful not to tug the ribbon cable connected near the bottom edge of the device.
    • Pry the last ribbon cable attached to the lower case using a plastic opening tool.
  10. Nintendo 3DS 2015 Circle Pad Replacement, Circle Pad: adım 10, 3 resimden 1. Nintendo 3DS 2015 Circle Pad Replacement, Circle Pad: adım 10, 3 resimden 2. Nintendo 3DS 2015 Circle Pad Replacement, Circle Pad: adım 10, 3 resimden 3.
    • Locate the joystick assembly near the top right corner of the motherboard.
    • Remove the two 8mm Phillips #00 screws from the back of the joystick.
    • Use the flat end of the spudger to pry off the joystick pad from its plastic housing.
  11. Nintendo 3DS 2015 Circle Pad Replacement: adım 11, 2 resimden 1. Nintendo 3DS 2015 Circle Pad Replacement: adım 11, 2 resimden 2.
    • Lift the joystick pad and place it on its back. This will reveal the ribbon cable connected to the joystick pad.
    • Use the flat end of the spudger to pry up the retaining flap for the ribbon cable.
    • Lift the joystick out of the device.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Michael
149 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 4-6, Livingston Fall 2016 Cal Poly, Team 4-6, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S4G6
4 Üyeler
35 adet Kılavuz yazıldı
Bir Yorum
thank you for the help
Crichton Vance - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 44
Son 30 gün: 309
Her zaman: 6,679
