Ana içeriğe geç
Nintendo 3DS 2015 D Pad Replacement
Neye ihtiyacın var
  1. Nintendo 3DS 2015 D Pad Replacement, Battery: adım 1, 1 resimden 1.
    • Unscrew the two 3mm Phillips #0 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
  2. Nintendo 3DS 2015 D Pad Replacement: adım 2, 2 resimden 1. Nintendo 3DS 2015 D Pad Replacement: adım 2, 2 resimden 2.
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
  3. Nintendo 3DS 2015 D Pad Replacement: adım 3, 3 resimden 1. Nintendo 3DS 2015 D Pad Replacement: adım 3, 3 resimden 2. Nintendo 3DS 2015 D Pad Replacement: adım 3, 3 resimden 3.
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
  4. Nintendo 3DS 2015 D Pad Replacement, SD Card Reader: adım 4, 1 resimden 1.
    • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
    • The bottom of the SD card reader should slightly pop out after removing the screws.
  5. Nintendo 3DS 2015 D Pad Replacement: adım 5, 1 resimden 1.
    • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
    • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
    • Reorient the device so that the power jack faces you.
  6. Nintendo 3DS 2015 D Pad Replacement: adım 6, 2 resimden 1. Nintendo 3DS 2015 D Pad Replacement: adım 6, 2 resimden 2.
    • Lift the SD card reader gently.
    • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
    • Lift the SD card reader out off of the lower casing.
  7. Nintendo 3DS 2015 D Pad Replacement, Lower Case: adım 7, 3 resimden 1. Nintendo 3DS 2015 D Pad Replacement, Lower Case: adım 7, 3 resimden 2. Nintendo 3DS 2015 D Pad Replacement, Lower Case: adım 7, 3 resimden 3.
    • Reorient the device so that the game slot now faces you.
    • Remove the two rubber bumpers along the top of the device using tweezers.
    • Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
  8. Nintendo 3DS 2015 D Pad Replacement: adım 8, 2 resimden 1. Nintendo 3DS 2015 D Pad Replacement: adım 8, 2 resimden 2.
    • Lift the top edge of the lower case slightly off on the 3DS.
    • Don't pull the lower casing completely off, you may break those connections. There are ribbon cables that must be disconnected first.
    • Pry the ribbon cable socket under the right trigger using a plastic opening tool.
    • Pry the ribbon cable socket under the infrared receiver cover using a plastic opening tool.
  9. Nintendo 3DS 2015 D Pad Replacement: adım 9, 3 resimden 1. Nintendo 3DS 2015 D Pad Replacement: adım 9, 3 resimden 2. Nintendo 3DS 2015 D Pad Replacement: adım 9, 3 resimden 3.
    • Open the device slowly from its top edge. Be careful not to tug the ribbon cable connected near the bottom edge of the device.
    • Pry the last ribbon cable attached to the lower case using a plastic opening tool.
  10. Nintendo 3DS 2015 D Pad Replacement, Gamecard Reader: adım 10, 2 resimden 1. Nintendo 3DS 2015 D Pad Replacement, Gamecard Reader: adım 10, 2 resimden 2.
    • Locate the gamecard reader near the bottom right corner of the motherboard.
    • Unscrew the four 3mm Phillips #00 screws along the edge of the gamecard reader.
    • Lift the black latch on the ZIF connector along the right side of the reader using a plastic opening tool.
  11. Nintendo 3DS 2015 D Pad Replacement: adım 11, 2 resimden 1. Nintendo 3DS 2015 D Pad Replacement: adım 11, 2 resimden 2.
    • Pry the ribbon cable from its socket, just left of the joystick, using the flat side of a spudger.
    • Grab the right edge of the gamecard reader and lift it out of the device, watching to make sure the ribbon cables don't snag.
  12. Nintendo 3DS 2015 D Pad Replacement, D Pad: adım 12, 2 resimden 1. Nintendo 3DS 2015 D Pad Replacement, D Pad: adım 12, 2 resimden 2.
    • Remove the four 3mm Phillips #00 screws from the four corners of the D pad board.
    • Lift the D pad board out of the device.
  13. Nintendo 3DS 2015 D Pad Replacement: adım 13, 2 resimden 1. Nintendo 3DS 2015 D Pad Replacement: adım 13, 2 resimden 2.
    • Peel the rubber piece, backing the D pad, out of the device.
    • Lift the D pad out of the device with a pair of tweezers.
Sonuç
Tyler Starr
1.509 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-6, Livingston Fall 2016 Cal Poly, Team 4-6, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S4G6
4 Üyeler
35 adet Kılavuz yazıldı
4 Yorum
I think you missed a few steps after step 9. There is no mention of removing the 3DS Cartridge reader or Circle Pad.
jharris - Yanıt
Jharris is right
Birby B. - Yanıt
Thanks for pointing that out! I think it is fixed now.
-Tyler
Tyler Starr -
My new 3DS d-pad is stuck in the up direction, what could be the problem?
Flute_Boi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 29
Son 30 gün: 104
Her zaman: 3,052
