Ana içeriğe geç
Nintendo 3DS 2015 SD Card Reader Replacement
Neye ihtiyacın var
  1. Nintendo 3DS 2015 SD Card Reader Replacement, Battery: adım 1, 1 resimden 1.
    • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
  2. Nintendo 3DS 2015 SD Card Reader Replacement: adım 2, 2 resimden 1. Nintendo 3DS 2015 SD Card Reader Replacement: adım 2, 2 resimden 2.
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
  3. Nintendo 3DS 2015 SD Card Reader Replacement: adım 3, 3 resimden 1. Nintendo 3DS 2015 SD Card Reader Replacement: adım 3, 3 resimden 2. Nintendo 3DS 2015 SD Card Reader Replacement: adım 3, 3 resimden 3.
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
  4. Nintendo 3DS 2015 SD Card Reader Replacement, SD Card Reader: adım 4, 1 resimden 1.
    • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
    • The bottom of the SD card reader should slightly pop out after removing the screws.
  5. Nintendo 3DS 2015 SD Card Reader Replacement: adım 5, 1 resimden 1.
    • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
    • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
    • Reorient the device so that the power jack faces you.
  6. Nintendo 3DS 2015 SD Card Reader Replacement: adım 6, 2 resimden 1. Nintendo 3DS 2015 SD Card Reader Replacement: adım 6, 2 resimden 2.
    • Lift the SD card reader gently.
    • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
    • Lift the SD card reader out off of the lower casing.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Tyler Starr
1.765 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-6, Livingston Fall 2016 Cal Poly, Team 4-6, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S4G6
4 Üyeler
45 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 63
Son 30 gün: 263
Her zaman: 8,904
