Ana içeriğe geç
Nintendo 3DS IR Board Replacement
Neye ihtiyacın var
  1. Nintendo 3DS IR Board Replacement, Back Cover: adım 1, 1 resimden 1.
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Nintendo 3DS IR Board Replacement: adım 2, 2 resimden 1. Nintendo 3DS IR Board Replacement: adım 2, 2 resimden 2.
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS IR Board Replacement, Battery: adım 3, 3 resimden 1. Nintendo 3DS IR Board Replacement, Battery: adım 3, 3 resimden 2. Nintendo 3DS IR Board Replacement, Battery: adım 3, 3 resimden 3.
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Nintendo 3DS IR Board Replacement, Lower Case: adım 4, 1 resimden 1.
    • Remove the nine 6.3 mm black Phillips screws from the lower case.
    • These screws will strip very easily unless you use the correct size bit. Apply pressure to the screws while turning to avoid stripping them.
    • Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
  5. Nintendo 3DS IR Board Replacement: adım 5, 3 resimden 1. Nintendo 3DS IR Board Replacement: adım 5, 3 resimden 2. Nintendo 3DS IR Board Replacement: adım 5, 3 resimden 3.
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
  6. Nintendo 3DS IR Board Replacement, IR Board: adım 6, 3 resimden 1. Nintendo 3DS IR Board Replacement, IR Board: adım 6, 3 resimden 2. Nintendo 3DS IR Board Replacement, IR Board: adım 6, 3 resimden 3.
    • Use the flat end of a spudger to lightly pry the IR board off the motherboard.
    • Grab the edges of the IR board with two fingers and lift it from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
David Hodson
150.493 İtibar
127 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 51
Her zaman: 8,623
