Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Replace the left shoulder button on your 3DS and regain L-button functionality.
Neye ihtiyacın var
Insert a plastic opening tool into the notch in the lower case above the battery.
Pry the battery up with the plastic opening tool.
Grab the top edge of the battery and lift it out of the lower case.
Remove the nine 6.3 mm black Phillips screws from the lower case.
Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
Remove the three 3.6 mm Phillips screws from the button housing.
42 farklı kişi bu kılavuzu tamamladı.
