Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Unscrew the four Phillips #00 screws along the top of the back cover.
Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
Pull the back cover up and away from the rest of the device to remove it.
Insert a plastic opening tool into the notch in the lower case above the battery.
Pry the battery up with the plastic opening tool.
Grab the top edge of the battery and lift it out of the lower case.
Remove the nine 6.3 mm black Phillips screws from the lower case.
Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
Lift the bottom edge of the lower case off the rest of the 3DS.
Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
Remove the lower case from the device.
Remove the three 3.6 mm Phillips screws from the button housing.
Insert a plastic opening tool under the left side of the left shoulder button cover.
Pry the black plastic cover up from the lower case.
Grab the cover and lift it off of the lower case.
Press lightly on the back of the button until it becomes unattached. Be careful not to lose the small spring and pin behind the plastic button.
42 farklı kişi bu kılavuzu tamamladı.
