Ana içeriğe geç
Nintendo 3DS Right Shoulder Button Replacement
Neye ihtiyacın var
  1. Nintendo 3DS Right Shoulder Button Replacement, Back Cover: adım 1, 1 resimden 1.
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
    #00 screwdriver is too big... probably need a #000
    thomascroguennec - Yanıt
    #00 will work - but you must press down firmly and sort of jerk the screw out a few degrees at a time. If you don't press firmly, the screws strip very easily. Using #000 will strip the screws more easily.
    Tai -
    I used a #0 without any issues and 0 stripped. I used the #0 for all screws internally and externally. The head was sharp and I applied adequate amounts of pressure when loosening the screw.
    Ben Kevan -
    The correct screwdriver should be a JIS, or you can get a screwdriver specific for the 3DS from other sites for less than $2
    Oscar - Yanıt
    do you have to buy it
    deeznuts -
    Where would I buy a screwdriver specifically for the 3DS? Also would it work on the DS? I need to replace the battery for my DS.
    Caitlin Lumsden -
    I used Phillips #000 and it worked like a charm, i need to order a new SD board or do you guys think i should send it. What happened is that it got water damaged and everything works fine when i opened it everything looked fine no signs of water corrosion everything on the 3DS works exept it always give me a message saying the SD card is locked and i know for a fact it isnt locked i already tried using 3 different SD cards and none of them are lock protected and yes they are formatted as well. I need help
    Leo Torres - Yanıt
    there's a switch on the SD card, switch it and it will be unlocked again. it happened to me once too.
    Bagel -
    david hodson you are incredible. literally all you need to do is heat the screen up and pry it off and you make them take apart the whole thing
    melody - Yanıt
    You've done this?
    magykmaster -
    I have to ask the same question. If just the glass display is broken, and you're heating it up to remove the glass, is it really necessary to remove everything? Doesn't like like it is necessary
    Wade -
    I just did it your way and it went fine. didnt even have to remove the battery. This is incredible misstep on the authors part.
    patrick -
    only take out the screen for a motherboard removal? Are you using the wrong guide or was this guide used for two different repairs?
    Reed Deemer -
    I used a PH0x50, but it wasn't easy.
    John - Yanıt
    This may be a dumb question but where do I buy the 3DS upper screen?
    John - Yanıt
    eBay... Just do a search for the 3DS Upper screen. $9.49 & it comes with the tools.
    Gary Darnell -
    The LCD screen I ordered came with all the tools I needed except a pair of tweezers. All in all it was about $14.00 and a little bit of my time.
    Gary Darnell - Yanıt
    Does anyone know where I can find the right bumper button for a 3ds? I can't find it on ebay must of damaged it playing smash bros.
    Steven Castro Parrilla - Yanıt
    Really wish I had read the comments first... How about instead of the warning saying to press down hardly and go slow, you say to use the correct screwdriver size like others mentioned in the comments. I not only stripped multiple screws, even after putting a glove on for more pressure, I bent my screwdriver from pressing down so hard. Granted it's a cheap jeweler's kit screwdriver, but it still would've been nice to not have that problem and be informed of the right size in the first place.
    hockeymorgan35 - Yanıt
    Got my tools one day after ordering, as I live a couple hours away from the supplier, Will post again when i try guide.
    nintendokakashi - Yanıt
    I tried doing this with a #00 Philips but it just didn't turn
    Acrobatic Mars01 - Yanıt
    Hello there, I need some assistance I have done a full housing replacement I have everything working except the 3d slider . The 3D option is always on can someone let me know which flex it is or what I am forgetting . Thanks guys !
    Noe Ibarra - Yanıt
    The 3D light lets you know there is a 3D option available for the current game you’re playing. Usually, it is always on, except when you’re playing a game that doesn’t support 3D. Turning the 3D slider off does not turn off the 3D LED.
    Scott D -
    I've always been lucky with these four, and at the time it was my first disassembly so I didn't know what stripping a screw was!
    FarmYard Gaming - Yanıt
    These screws don't strip easily, however, the screws at step 4 do.
    TheBlueInkling -
  2. Nintendo 3DS Right Shoulder Button Replacement: adım 2, 2 resimden 1. Nintendo 3DS Right Shoulder Button Replacement: adım 2, 2 resimden 2.
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
    Rember to transfer the model number sticker to the new cover
    Caleb Mezenberg (Caleb) - Yanıt
  3. Nintendo 3DS Right Shoulder Button Replacement, Battery: adım 3, 3 resimden 1. Nintendo 3DS Right Shoulder Button Replacement, Battery: adım 3, 3 resimden 2. Nintendo 3DS Right Shoulder Button Replacement, Battery: adım 3, 3 resimden 3.
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Nintendo 3DS Right Shoulder Button Replacement, Lower Case: adım 4, 1 resimden 1.
    • Remove the nine 6.3 mm black Phillips screws from the lower case.
    • These screws will strip very easily unless you use the correct size bit. Apply pressure to the screws while turning to avoid stripping them.
    • Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
    Had to give up at this point. Tried using the ifixit #00 phillips screwdriver to take out two screws and ended up stripping them.
    Demios - Yanıt
    Stuck at the same spot, those screws are in there really tight.
    John Pasula - Yanıt
    Ruined my screws because of incorrect head, thanks!
    3dsuser - Yanıt
    I had so much trouble with these screws, I gave up. Unfortunately, I can't accept failure so tried again. I figured out if you turn it right before you loosen it worked. Maybe it was just me, but I turned it right then kept pressure as I turned to loosen. I was surprised I hadn't stripped any screws out.
    Nicole Bauer - Yanıt
    Does anyone have any idea of how to remove these screws. I've pretty badly stripped the screws and I've gone to 20+ pages trying to figure this. I'm considering just prying the !@#$ thing.
    Vino - Yanıt
    use a dremil and make it a flat head
    Ralph Prowant -
    ruined my screws here too...what the !@#$ nintendo?
    trying to survive a nuclear meltdown inside the !@#$ thing
    Hamza Jarkas - Yanıt
    More like trying to subtly enforce planned obsolescence by not allowing you to make repairs to your device.
    Ullyssys -
    I used a #00 Philips 1/8" bit with no problem; however, the narrow diameter of the counter sunk hole can inhibit making secure contact with the screw head. You can be using the right bit (#00) but if the diameter of the bit shaft is too big you won't get proper contact.
    I found this to be an excellent guide. Thanks
    Dave W - Yanıt
    Unscrewed the nine 6.3 mm screws using the J000 bit from the iFixit 54 bit driver kit without much effort & without stripping the screw heads. Just gotta really position the bit correctly on the screw to have a proper fitting & not strip the screw heads.
    STZ9 - Yanıt
    The screws didn't strip but the philips screw driver did? @__@
    These are rough either way.
    John Zhou - Yanıt
    I used a "Whia 273 - PH000x40" screwdriver and held it firmly pushing the palm of my hand on the yellow end of the screwdriver and rocked the screw slightly (counter clockwise and clockwise) until it started to move. Then, without letting up on the pressure I carefully backed it out. The screwdriver is excellent because it is hardened (unlike some cheapo's out there) and the very tip is blunt not sharp. If the tip is too sharp, the point will bottom out in the screw and the sides that do all the work, won't be able to fully contact the inside of the screw. This screwdriver fits so well that the screws actually stick to it once they are removed. If the screwdriver moves AT ALL when you initially try it in the screw, STOP and find a better one. Also, start with the screws in the center, somehow they seem a little easier until you get the feel for it.
    Paul -
    Push down hard and turn counter-clockwise, or push down and rotate 3DS counter-clockwise until screw is loose.
    Jonathan - Yanıt
    Had the exact same problem, even tried the #000 screw driver too. Stripped the screws due to how tightly they are screwed in there and how easy they strip. I am now unsure what to do from here or if all I can do is give up.
    Sean Baldwin - Yanıt
    I second the one who suggested the Whia 273 PH000x40 screwdriver. I had a terrible time unscrewing these screws, and almost stripped them using a cheaper #000 screwdriver. Also tried a 3/16" flathead and destroyed the screwdriver. I bought the Whia and glad I did. It fit perfectly and did not slip at all. DEFINITELY recommend purchasing this high-quality screwdriver. Cost about $10 but well worth it to avoid the hassle.
    pbrazis - Yanıt
    The best way I found that works quite well, if you find a screwdriver or bit that is good enough: hold the screwdriver or bit with tons of pressure, and rotate the 3DS clockwise! It will come out in 5-6 rotations, you can do this step in about 10 minutes this way (put down a cloth first, don't scratch the front!)
    Gannon Trueman - Yanıt
    I HAVE A WAY TO GET OUT THE STRIPED SCREW. Like you, I had screwed up and tried everything to get the screw out. Do NOT try the glue in that tiny hole, you will get the screw glued permanently in there. The rubber band doesn't work in that tight space either. As desperate as I was, I was trying anything from nail polish to cramming the screw driver in as hard as I possible could. Until I realized that I had a drill. Yes, with the smallest head, I drilled into the screw a little bit, messed with the part I was trying to get out, drilled a little more, messed around, and then finally on my last attempt, I had successfully drilled off the top of the screw rendering the part free. It doesn't matter which drill you use as long as you can fit the head into the hole. Then drill forward like you are trying to drill a hole through wood. Now the only problem is that the remainder of the screw will be stuck in its place. All you really have to do is get a set of pliers and twist that puppy out. And there you go!
    YuuChan - Yanıt
    Most likely though, if you have all the other screws out and only have one striped screw, the part should just pop off and you wouldn't have to drill the entire head off the screw.
    YuuChan - Yanıt
    Got a brand new #00 screw drive and it striped the first time used it. So now I'm using eyeglass repair kit screw driver and it lasts longer that the one I got of of eBay.
    And I tried all of those tactics that people have been giving and none of them are working.
    The wiha 273 PH #000×40 unsrews it easily! It has a magnet on it!
    Najee - Yanıt
    I’m cant get these %#*@ screws out i want to die…
    FRØSTBIT3 - Yanıt
    Oh god, someone help i can’t get them out.
    Mark LaPierre - Yanıt
    omg everyone is struggling in here smh. I used my PH000 screwdriver made sure it went in aligned to the screws and applied pressure while turning counterclockwise. once it started the screw started lifting i stopped applying pressure and they lifted beautifully. saved damaging my screws with this technique. I also used the same screwdriver size to remove the orange screw where the game slot is. Yall are welcome lol
    Evelyn Avalos - Yanıt
    USE A DIFFERENT SCREWDRIVER.
    I was stuck on this for an hour. If your screwdriver is very thin, you won't get the grip necessary if your screws are on tight. I thought my screws were stripped but I switched to a bigger screwdriver and it was effortless. Just MAKE SURE IT IS A 00 PHILLIPS HEAD.
    brendon - Yanıt
    Use a JIS screwdriver, not Phillips! I bought the recommended screwdriver from this website and couldn't remove any screws. I went and purchased a J00 screwdriver and removed them quickly.
    danielle - Yanıt
    I used what I believe is a 1.5mm screwdriver which I received in one of those 60 in 1 precision screwdriver sets. It fit perfectly and much more snugly compared to any of the J0 - J000 bits.
    Andrew - Yanıt
    You should change the Screwdriver Type used. A Philipshead can damage Screws and/or Console. Use JIS Type-J00, which iFixIt sells, yes.
    J022 - Yanıt
  5. Nintendo 3DS Right Shoulder Button Replacement: adım 5, 3 resimden 1. Nintendo 3DS Right Shoulder Button Replacement: adım 5, 3 resimden 2. Nintendo 3DS Right Shoulder Button Replacement: adım 5, 3 resimden 3.
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
    When assembling, make sure that L ribbon is inside the case and R ribbon is not under the aluminium battery case. I got them both cut accidentally and had to replace :(
    Marek Jakóbiak - Yanıt
    Man muss die Folienkabel für die Tasten nicht unbedingt abziehen wenn man einen Gegenstand dahinter stellt, an dem man den Deckel senkrecht anlehnen kann.
    Jean - Yanıt
    Don't listen to the german guy. It's very easy to pop back
    Bruno N - Yanıt
  6. Nintendo 3DS Right Shoulder Button Replacement, Right Shoulder Button: adım 6, 3 resimden 1. Nintendo 3DS Right Shoulder Button Replacement, Right Shoulder Button: adım 6, 3 resimden 2. Nintendo 3DS Right Shoulder Button Replacement, Right Shoulder Button: adım 6, 3 resimden 3.
    • Remove the three 3.6 mm Phillips screws securing the metal battery shield to the lower case.
    • Lift the battery shield up and out of the lower case.
  7. Nintendo 3DS Right Shoulder Button Replacement: adım 7, 1 resimden 1.
    • Remove the 3.6 mm Phillips screw from the right shoulder button cover.
    my shoulder button did not have this screw and no past work has been preformed on it.
    Rcola - Yanıt
  8. Nintendo 3DS Right Shoulder Button Replacement: adım 8, 3 resimden 1. Nintendo 3DS Right Shoulder Button Replacement: adım 8, 3 resimden 2. Nintendo 3DS Right Shoulder Button Replacement: adım 8, 3 resimden 3.
    • Insert a plastic opening tool under the left side of the right shoulder button cover.
    • Pry the black plastic cover up from the lower case.
    • Grab the cover and lift it off of the lower case.
    • If the shoulder button contact and ribbon cable come off with the cover, be sure to reinstall them in the correct orientation.
  9. Nintendo 3DS Right Shoulder Button Replacement: adım 9, 3 resimden 1. Nintendo 3DS Right Shoulder Button Replacement: adım 9, 3 resimden 2. Nintendo 3DS Right Shoulder Button Replacement: adım 9, 3 resimden 3.
    • Lift the right shoulder button out of the lower case.
    • The shoulder button is held in place by a metal pin, and houses a small spring. Take care not to lose track of either of these pieces when removing the shoulder button.
    So how do I actually replace it? Is it just cleaning and reassembling or do I need to get new parts?
    Alannah M - Yanıt
Sonuç
75 farklı kişi bu kılavuzu tamamladı.
David Hodson
150.493 İtibar
127 adet Kılavuz yazıldı
19 Yorum
Well done, thanks for the help, I had small problems with step 9 because of all those small parts but I managed to put everything back as it was. Thanks again :D
BlackZX - Yanıt
The ribbon came off the socket, now it is stuck and we cannot pull it out. How do you remove the socket without the ribbon. We attempted tweezers, but it did not budge. May have scratched things up a bit too. Help!! Thank you! We just want to pull it out and get another replacement right shoulder ribbon.
misdiva001 - Yanıt
Did you ever figure out how to get it out? I have the same problem. I changed the ribbon with a 3rd party part and the bad solder job broke and the part is still left in the socket. My only option is to use crazy glue and a pin or something small to glue to it and then pull it out…but I don’t have any krazy glue!
Chris -
Amazing guide, thank you!!
Daniel O - Yanıt
It was great! Phenomenal! I loved it! But... What happens if I accidentally snapped the L button's ribbon cable..? Can I just replace it..? Somehow..?
dalton haglund - Yanıt
Dalton,
You can order replacement L&R ribbons on Amazon, they're like $5.
Proudly Built -
Excellent guide, worked like a charm for replacing both shoulder buttons.
Proudly Built - Yanıt
Where can I buy replacement shoulder buttons? Or is it enough to just clean the area and get any blockage out (like dust)?
kelsey5656 - Yanıt
Is this safe?
Pale_Rider - Yanıt
For everyone who had problems with this. After or during Step 9, it is possible that the R button will come off entirely. This will mean the spring is no longer in place, and a small metal rod might also come off. The optimal way to fix this is to place the spring back in first alongside the button (the spring rests on the plastic as seen in the photo for Step 9), and then put the metal rod through the whole. You have to be careful when putting the ribbon cable. You may also have to bend it slightly (see how Nintendo has bent it) for optimal fit. You have to be careful as these ribbons are very easy to break or cut.
Faust - Yanıt
Just wondering, does it still work well without the rod?
Adam McCormick -
Excellent walk through, replaced both buttons and everything is working!
Joe - Yanıt
Managed to fix the L button (mostly), wanted a poke around the R button which had been screwed for years. Definitely time to order a replacement. It took me half an hour to comprehend how to put the R button back together because I’m an idiot and forgot what to do, but found a video guide to help me. Loved the guide either way, disassembled it down to there easily thanks to this.
I have the #00 from the store but I can’t get the screws out from for step four… Help D: They haven’t been stripped or anything I just, can’t make them budge.
Erica Staab - Yanıt
I personally found that a #000 worked better, so if anyone else has this issue that could be it. Alternatively, you might just need to push down hard and turn. As a somewhat related aside, this repair made me really glad that I bought a full repair kit - I really needed the tweezers for some of the finicky parts (though it doesn’t help that my fingers are too large for their own good).
Jonah H-W -
I can't get the metal pin back in on step 9, can anyone help?
Adam McCormick - Yanıt
This was a great guide! I have never worked on a 3DS and this guide helped a ton!
Jake Allen - Yanıt
I replaced the right shoulder and it went perfectly BUT, I went to test it afterwards and it still wouldn't register the input of the button, any advice would be appreciated
Maxus Drakon - Yanıt
Thanks for this guide and the L button one. Finally have working shoulder buttons again! Which means... I can finally play Majora's Mask 3D!!!!
Jonathan VanHeiden - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 21
Son 7 gün: 185
Son 30 gün: 912
Her zaman: 110,271
