Giriş
Replace the stylus housing in your Nintendo 3DS and give your metal stylus a comfortable place to sleep.
Neye ihtiyacın var
Insert a plastic opening tool into the notch in the lower case above the battery.
Pry the battery up with the plastic opening tool.
Grab the top edge of the battery and lift it out of the lower case.
Remove the nine 6.3 mm black Phillips screws from the lower case.
Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
Bir başkası bu kılavuzu tamamladı.
