Giriş
This guide will allow you to repair a broken circle pad on your 2015 Nintendo 3DS XL. If your circle pad no longer functions well or doesn't function at all this is the guide for you. All you will need is a new circle pad, a few screwdrivers and with a little patience your 3DS will once again have full functionality.
Parçalar
Turn the device so that the back cover is facing you and locate the two screws at the top of the back cover.
Using the Phillips #000 screwdriver, loosen the screws on the back cover.
Gently pry the tabs on the side of the device with the metal spudger or your thumbnail and lift off the back cover.
Remove the two rubber bumpers on the back of the device with a thumb tack.
Using the Phillips #00 screwdriver, remove all 8 of the screws holding the bottom cover to the motherboard.
Lift off the bottom cover, being sure not to disconnect the two ZIF connectors for the L/R buttons on the back of the device.
Take the new circle pad assembly and insert the cable back into the open ZIF connector and close it using the spudger.
Ensure the internal component of the circle pad is correctly oriented with a small screwdriver or spudger.
Gently place the new circle pad back into its place and secure with the screws.
10 farklı kişi bu kılavuzu tamamladı.
2 Yorum
oh my gosh this is the best guide my grand-son and i fixed his sons 3DS he is so happy
