Ana içeriğe geç
Nintendo 3DS XL Hinge/Midframe Replacement
Neye ihtiyacın var
  1. Nintendo 3DS XL Hinge/Midframe Replacement, Hinge/Midframe: adım 1, 2 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement, Hinge/Midframe: adım 1, 2 resimden 2.
    • Flip the 3DS XL upside down.
  2. Nintendo 3DS XL Hinge/Midframe Replacement: adım 2, 1 resimden 1.
    • Remove the two 4.2 mm screws from the back cover using a Phillips #00 screwdriver.
  3. Nintendo 3DS XL Hinge/Midframe Replacement: adım 3, 1 resimden 1.
    • Use an opening tool to pry the cover loose and lift the back cover.
    • Caution: Make sure to lift the side with the screws up first as to not break hooks on the cover.
  4. Nintendo 3DS XL Hinge/Midframe Replacement: adım 4, 2 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement: adım 4, 2 resimden 2.
    • Use an opening tool to remove the battery.
  5. Nintendo 3DS XL Hinge/Midframe Replacement: adım 5, 1 resimden 1.
    • Remove the six 6.2 mm screws from the back cover using a Phillips #00 screwdriver.
    • Remove the single 2.3 mm screw from the back cover using a Phillips #00 screwdriver.
  6. Nintendo 3DS XL Hinge/Midframe Replacement: adım 6, 3 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement: adım 6, 3 resimden 2. Nintendo 3DS XL Hinge/Midframe Replacement: adım 6, 3 resimden 3.
    • Use your hands to carefully remove the back cover at an angle, while keeping it connected to the top edge with caution regarding the ribbons.
  7. Nintendo 3DS XL Hinge/Midframe Replacement: adım 7, 2 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement: adım 7, 2 resimden 2.
    • Use a pair of tweezers to carefully detach both of the ribbon cables connected to the back cover.
  8. Nintendo 3DS XL Hinge/Midframe Replacement: adım 8, 2 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement: adım 8, 2 resimden 2.
    • Remove the two 7.5 mm screws from the white plate.
    • Use your fingers to lift it off the space carefully.
  9. Nintendo 3DS XL Hinge/Midframe Replacement: adım 9, 1 resimden 1.
    • Use a pair of tweezers to remove the small plastic circle from the opened space.
  10. Nintendo 3DS XL Hinge/Midframe Replacement: adım 10, 2 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement: adım 10, 2 resimden 2.
    • Use your fingers to carefully disconnect the small green rectangle.
  11. Nintendo 3DS XL Hinge/Midframe Replacement: adım 11, 1 resimden 1.
    • Remove the ten 3 mm screws from the motherboard.
  12. Nintendo 3DS XL Hinge/Midframe Replacement: adım 12, 2 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement: adım 12, 2 resimden 2.
    • On the bottom right corner, remove the small plastic piece using a pair of tweezers.
  13. Nintendo 3DS XL Hinge/Midframe Replacement: adım 13, 2 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement: adım 13, 2 resimden 2.
    • On the bottom left corner, remove the small plastic piece using a pair of tweezers.
  14. Nintendo 3DS XL Hinge/Midframe Replacement: adım 14, 2 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement: adım 14, 2 resimden 2.
    • With caution yet with slight force, use a pair of tweezers to pull and disconnect the ribbon cable from the latch on the top right corner.
  15. Nintendo 3DS XL Hinge/Midframe Replacement: adım 15, 2 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement: adım 15, 2 resimden 2.
    • With caution yet with slight force, use a pair of tweezers to pull and disconnect the second ribbon cable from the latch on the top right corner.
  16. Nintendo 3DS XL Hinge/Midframe Replacement: adım 16, 2 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement: adım 16, 2 resimden 2.
    • With caution yet with slight force, use your hands to lift the screen and the green motherboard from the frame.
    • Caution: There is still a ribbon cable connected, so do not suddenly remove what was lifted.
  17. Nintendo 3DS XL Hinge/Midframe Replacement: adım 17, 2 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement: adım 17, 2 resimden 2.
    • With caution yet with slight force, use a pair of tweezers to pull and disconnect the ribbon cable at the hinge from the latch.
  18. Nintendo 3DS XL Hinge/Midframe Replacement: adım 18, 2 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement: adım 18, 2 resimden 2.
    • Use your fingers to disconnect the green rectangle from the small green cable.
  19. Nintendo 3DS XL Hinge/Midframe Replacement: adım 19, 2 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement: adım 19, 2 resimden 2.
    • Flip the 3DS XL right side up and open it.
  20. Nintendo 3DS XL Hinge/Midframe Replacement: adım 20, 3 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement: adım 20, 3 resimden 2. Nintendo 3DS XL Hinge/Midframe Replacement: adım 20, 3 resimden 3.
    • Use a pair of tweezers to remove the small rubber squares from each corner of the front screen.
  21. Nintendo 3DS XL Hinge/Midframe Replacement: adım 21, 1 resimden 1.
    • Remove the four 4.3 mm screws from the top screen using a Phillips #00 screwdriver.
  22. Nintendo 3DS XL Hinge/Midframe Replacement: adım 22, 3 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement: adım 22, 3 resimden 2. Nintendo 3DS XL Hinge/Midframe Replacement: adım 22, 3 resimden 3.
    • Use your hands to remove the top cover by pushing the cover horizontally away from the hinges, as to not break any plastic hooks.
  23. Nintendo 3DS XL Hinge/Midframe Replacement: adım 23, 2 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement: adım 23, 2 resimden 2.
    • Flip the 3DS XL upside down and find the top left hinge.
    • In the small opening, use a small opening tool to push the small white plastic piece down towards the other hinge.
    • Caution: A decent amount of force will be needed to push it down, so use a small but sturdy object that can fit in the opening to push it down.
  24. Nintendo 3DS XL Hinge/Midframe Replacement: adım 24, 2 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement: adım 24, 2 resimden 2.
    • Use a pair of tweezers to remove the small black plastic piece covering the hinge.
  25. Nintendo 3DS XL Hinge/Midframe Replacement: adım 25, 2 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement: adım 25, 2 resimden 2.
    • Use a pair of tweezers to remove the small clear plastic piece from the hinge.
    • At this point you can remove the bottom frame from the left hinge using your hands.
  26. Nintendo 3DS XL Hinge/Midframe Replacement: adım 26, 3 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement: adım 26, 3 resimden 2. Nintendo 3DS XL Hinge/Midframe Replacement: adım 26, 3 resimden 3.
    • At the top right hinge, use your hands to carefully slide the ribbon cables through a small gap next to the hinge to remove them from the bottom frame.
  27. Nintendo 3DS XL Hinge/Midframe Replacement: adım 27, 2 resimden 1. Nintendo 3DS XL Hinge/Midframe Replacement: adım 27, 2 resimden 2.
    • Use your fingers to remove all buttons and rubber covers from the old frame and place them into the new frame.
Sonuç
Bir başkası bu kılavuzu tamamladı.
FixitKevin
412 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 4-9, Kershman Fall 2023 CSU Los Angeles, Team 4-9, Kershman Fall 2023 üyesi
CSULA-KERSHMAN-F23S4G9
1 Üye
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 46
Son 7 gün: 249
Son 30 gün: 1,195
Her zaman: 3,724
