Ana içeriğe geç
Nintendo 3DS XL Microphone Replacement
Neye ihtiyacın var
  1. Nintendo 3DS XL Microphone Replacement, Remove the back cover screws: adım 1, 1 resimden 1.
    • Use a JIS 00 screwdriver to loosen the 4.2 mm‑long screws on the top edge of the back cover.
    • The screws have locking washers that prevent the screws from falling out. Keep these in place.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo 3DS XL Microphone Replacement, Remove the back cover: adım 2, 2 resimden 1. Nintendo 3DS XL Microphone Replacement, Remove the back cover: adım 2, 2 resimden 2.
    • Use a plastic opening tool to pry off the clips securing the back cover, starting at the top corners and working your way down.
    • Use your hands to keep the clips from reattaching.
    • Use your hands to remove the back cover.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo 3DS XL Microphone Replacement: adım 3, 3 resimden 1. Nintendo 3DS XL Microphone Replacement: adım 3, 3 resimden 2. Nintendo 3DS XL Microphone Replacement: adım 3, 3 resimden 3.
    • Insert the plastic opening tool into the opening located on the right side of the battery.
    • Pry the battery out of its recess and remove it.
    FixBot'a Sor
    Yorum Ekle
  4. Nintendo 3DS XL Microphone Replacement, Microphone: adım 4, 2 resimden 1. Nintendo 3DS XL Microphone Replacement, Microphone: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
    FixBot'a Sor
    Yorum Ekle
  5. Nintendo 3DS XL Microphone Replacement: adım 5, 2 resimden 1. Nintendo 3DS XL Microphone Replacement: adım 5, 2 resimden 2.
    • Remove the six 6.2 mm screws using a Phillips #000 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  6. Nintendo 3DS XL Microphone Replacement: adım 6, 1 resimden 1.
    • Remove the 2.3 mm screw located above the game cartridge slot with a Phillips #000 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Nintendo 3DS XL Microphone Replacement: adım 7, 3 resimden 1. Nintendo 3DS XL Microphone Replacement: adım 7, 3 resimden 2. Nintendo 3DS XL Microphone Replacement: adım 7, 3 resimden 3.
    • With a plastic opening tool pry off the lower case starting at the bottom edge and working around the perimeter.
    • Two ribbon cables connect the case to the circuit board. Be careful to not pull the case too hard and rip the ribbon cables.
    FixBot'a Sor
    Yorum Ekle
  8. Nintendo 3DS XL Microphone Replacement: adım 8, 3 resimden 1. Nintendo 3DS XL Microphone Replacement: adım 8, 3 resimden 2. Nintendo 3DS XL Microphone Replacement: adım 8, 3 resimden 3.
    • Remove the ribbon cables located underneath the left and right bumpers by prying up the base of the cables with a plastic opening tool.
    • Completely remove the lower case from the rest of the device and set aside.
    FixBot'a Sor
    Yorum Ekle
  9. Nintendo 3DS XL Microphone Replacement: adım 9, 3 resimden 1. Nintendo 3DS XL Microphone Replacement: adım 9, 3 resimden 2. Nintendo 3DS XL Microphone Replacement: adım 9, 3 resimden 3.
    • Position the device such that the game cartridge slot is located at the top.
    • Locate the microphone in the bottom left corner.
    • Using tweezers remove the microphone.
    • There will be a ribbon that connects the microphone to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  10. Nintendo 3DS XL Microphone Replacement: adım 10, 2 resimden 1. Nintendo 3DS XL Microphone Replacement: adım 10, 2 resimden 2.
    • Using the flat head side of the spudger carefully lift up the flap and remove the ribbon.
    • The attached microphone can now be removed.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Charlene Donlon
11.225 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-13, Regan Spring 2014 Cal Poly, Team 9-13, Regan Spring 2014 üyesi
CPSU-REGAN-S14S9G13
5 Üyeler
56 adet Kılavuz yazıldı
2Kılavuz Yorumları
Hello! Do these instructions apply to the New 3DS XL as well? I followed steps from 1-8, but when I get to step 9, the layout is different and I can’t find the mic. Any help would be greatly appreciated!
Melissa Cardenas - Yanıt Paylaş
please learn to repair the mic of new 3ds xl
andrew.hws - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 40
Son 30 gün: 158
Her zaman: 15,782
