Ana içeriğe geç
Nintendo 64 Rumble Pak Battery Replacement
Neye ihtiyacın var
  1. Nintendo 64  Rumble Pak Battery Replacement, Rumble Pak Battery: adım 1, 1 resimden 1.
    • Remove the Rumble Pak from the controller by pressing the release button and pulling the Rumble Pak out.
  2. Nintendo 64  Rumble Pak Battery Replacement: adım 2, 1 resimden 1.
    • Remove the battery cover from the Rumble Pak by pressing the tab and pulling the cover up.
  3. Nintendo 64  Rumble Pak Battery Replacement: adım 3, 1 resimden 1.
    • Press each battery toward the spring, then pull toward you to remove the batteries from the Rumble Pak.
    • When inserting the new batteries, make sure the positive (+) end of the battery touches the flat piece, and the negative (-) end touches the spring.
  4. Nintendo 64  Rumble Pak Battery Replacement: adım 4, 3 resimden 1. Nintendo 64  Rumble Pak Battery Replacement: adım 4, 3 resimden 2. Nintendo 64  Rumble Pak Battery Replacement: adım 4, 3 resimden 3.
    • Check for corrosion around the springs and the flat plate where the batteries touch.
    • Do not touch the corrosion. It may be battery acid.
    • Use a flat head screwdriver to chisel away the corrosion, and use a Q-tip to wipe it clean.
    • Do not use water to wet the Q-tip, as water can damage the Rumble Pak.
Sonuç
Carly Bowen
304 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team 3-6, Rauch SU 2015 Texas Tech, Team 3-6, Rauch SU 2015 üyesi
TTU-RAUCH-SU15S3G6
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 37
Her zaman: 4,023
